I would like to add a custom metric to model with Keras, I'm debugging my working code and I don't find a method to do the operations I need.
The problem could be described as a multi classification trough logistic multinomial regression. The custom metric I would like to implement is this:
(1/Number_of_Classes)*(TruePositivesClass1/TotalElementsClass1 + TruePositivesClass2/TotalElementsClass2 + ... + TruePositivesClassN/TotalElementsClassN)
Where Number_of_Classes must be calculate from batch, i.e something like np.unique(y_true).count() and and every summation item would be something like
len(np.where(y_true==class_i,1,0) == np.where(y_pred==class_i,1,0) )/np.where(y_true==class_i,1,0).sum()
In terms of confusion matrix (in the minimal form of 2 variables)
        True    False
True     15      3
False    12      1
The formula would be 0.5*(15)/(15+12) + 0.5*(1/(1+3))=0.4027
The code could be something like
def custom_metric(y_true,y_pred):
    total_classes = Unique(y_true) #How calculate total unique elements?
    summation = 0
    for _ in unique_value_on_target:
        # calculates Number of y_predict that are _
        true_predics_of_class = Count(y_predict,_)
        # calculates total number of items of class _ in batch y_true
        true_values = Count(y_true,_)
        value = true_predicts/true_values
       summation + = value
    return summation
My preprocessed data is a numpy array like x=[v1,v2,v3,v4,...,vn], and my objetive column is a nompy array y=[1, 0, 1, 0, 1, 0, 0, 1 ,..., 0, 1]
then, they are converted to tensors:
x_train = tf.convert_to_tensor(x)
y_train = tf.convert_to_tensor(tf.keras.utils.to_categorical(y))
Then, they are converted to tensorflow dataset objects:
train_ds = tf.data.Dataset.zip((tf.data.Dataset.from_tensor_slices(x_train),
                                tf.data.Dataset.from_tensor_slices(y_train)))
Later, I take a iterator:
 train_itr = iter(
          train_ds.shuffle(len(y_train) * 5, reshuffle_each_iteration=True).batch(len(y_train)))
and last, I take one element of iterator and train
x_train, y_train = train_itr.get_next()
model.fit(x=x_train, y=y_train, batch_size=batch_size, epochs=epochs,
          callbacks=[custom_callback], validation_data=test_itr.get_next())
So, since objects are dataset iterators, I can't find functions to operate them as I would like, in order to get the custom metric described.
type(y_pred)
L F
  • 548
  • 22
So you want calculate average recall wrt multiclass in the batch, here is my example code using numpy and tensorflow:
import tensorflow as tf
import numpy as np
y_t = np.array([[1, 0, 0, 0], [0, 1, 0, 0], [0, 1, 0, 0], [0, 0, 0, 1], [0, 0, 0, 1]], dtype=np.float32)
y_p = np.array([[1, 0, 0, 0], [1, 0, 0, 0], [0, 1, 0, 0], [0, 0, 0, 1], [0, 0, 0, 1]], dtype=np.float32)
def average_recall(y_true, y_pred):
    # Get indexes of both labels and predictions
    labels = np.argmax(y_true, axis=1)
    predictions = np.argmax(y_pred, axis=1)
    # Get confusion matrix from labels and predictions
    confusion_matrix = tf.math.confusion_matrix(labels, predictions).numpy()
    # Get number of all true positives in each class
    all_true_positives = np.diag(confusion_matrix)
    # Get number of all elements in each class
    all_class_sum = np.sum(confusion_matrix, axis=1)
    # Get rid of classes that don't show in batch
    zero_index = np.where(all_class_sum == 0)[0]
    all_true_positives = np.delete(all_true_positives, zero_index)
    all_class_sum = np.delete(all_class_sum, zero_index)
    print("confusion_matrix:\n {},\n all_true_positives:\n {},\n all_class_sum:\n {}".format(
                                            confusion_matrix, all_true_positives, all_class_sum))
    # Average TruePositives / TotalElements wrt all classes that show in batch
    return np.mean(all_true_positives / all_class_sum)
avg_recall = average_recall(y_t, y_p)
print(avg_recall)
Outputs:
confusion_matrix:
 [[1 0 0 0]
 [1 1 0 0]
 [0 0 0 0]
 [0 0 0 2]],
 all_true_positives:
 [1 1 2],
 all_class_sum:
 [1 2 2]
0.8333333333333334
Implement using only tensorflow:
y_t = tf.constant([[1, 0, 0, 0], [0, 1, 0, 0], [0, 1, 0, 0], [0, 0, 0, 1], [0, 0, 0, 1]], dtype=tf.float32)
y_p = tf.constant([[1, 0, 0, 0], [1, 0, 0, 0], [0, 1, 0, 0], [0, 0, 0, 1], [0, 0, 0, 1]], dtype=tf.float32)
    labels = tf.argmax(y_true, axis=1)
    predictions = tf.argmax(y_pred, axis=1)
    all_true_positives = tf.linalg.diag_part(confusion_matrix)
    all_class_sum = tf.reduce_sum(confusion_matrix, axis=1)
    mask = tf.not_equal(all_class_sum, tf.constant(0))
    all_true_positives = tf.boolean_mask(all_true_positives, mask)
    all_class_sum = tf.boolean_mask(all_class_sum, mask)
    return tf.reduce_mean(all_true_positives / all_class_sum)
print(avg_recall)
Outputs:
confusion_matrix:
 [[1 0 0 0]
 [1 1 0 0]
 [0 0 0 0]
 [0 0 0 2]],
 all_true_positives:
 [1 1 2],
 all_class_sum:
 [1 2 2]
tf.Tensor(0.8333333333333334, shape=(), dtype=float64)
Reference:
Calculate precision and recall for multiclass classification using confusion matrix
Mr. For Example
  • 4,173
