84
I'm struggling with following "error" in VSCode :
Argument for '--jsx' option must be: 'preserve', 'react-native', 'react'
Hence, react-scripts (create-react-app) automatically sets the jsx key to react-jsx value, when react value seems to work.
Actually, the code works perfectly and displays the page I want, but the IDE is underlining kinda everything as errors, saying :
Cannot use JSX unless the '--jsx' flag is provided.
Here is my tsconfig.json :
  "compilerOptions": {
    "target": "es5",
    "lib": [
      "dom",
      "dom.iterable",
      "esnext"
    "allowJs": true,
    "skipLibCheck": true,
    "esModuleInterop": true,
    "allowSyntheticDefaultImports": true,
    "strict": true,
    "forceConsistentCasingInFileNames": true,
    "noFallthroughCasesInSwitch": true,
    "module": "esnext",
    "moduleResolution": "node",
    "resolveJsonModule": true,
    "isolatedModules": true,
    "noEmit": true,
    "jsx": "react-jsx"
  "include": [
    "src"
, and my package.json (default one provided by create-react-app + packages updated) :
  "name": "front-office",
  "version": "0.1.0",
  "private": true,
  "dependencies": {
    "@testing-library/jest-dom": "^5.11.6",
    "@testing-library/react": "^11.2.2",
    "@testing-library/user-event": "^12.2.2",
    "@types/jest": "^26.0.15",
    "@types/node": "^14.14.9",
    "@types/react": "^17.0.0",
    "@types/react-dom": "^17.0.0",
    "bootstrap": "^4.5.3",
    "react": "^17.0.1",
    "react-bootstrap": "^1.4.0",
    "react-dom": "^17.0.1",
    "react-scripts": "4.0.1",
    "typescript": "^4.1.2",
    "web-vitals": "^1.0.1"
  "scripts": {
    "start": "react-scripts start",
    "build": "react-scripts build",
    "test": "react-scripts test",
    "eject": "react-scripts eject"
  "eslintConfig": {
    "extends": [
      "react-app",
      "react-app/jest"
  "browserslist": {
    "production": [
      ">0.2%",
      "not dead",
      "not op_mini all"
    "development": [
      "last 1 chrome version",
      "last 1 firefox version",
      "last 1 safari version"
I'm using the latest version of Typescript, and I updated all my packages with ncu, closed/opened VSCode (works sometimes with tsconfig !) and nothing seems to resolve that.
I'm pretty sure it's a VSCode problem, but I'm running out of ideas about how to resolve that.
Any of you guys got ideas ?
Edit:
If you followed the above steps and VSCode still shows the "-jsx" error, make sure you have disabled the 'TypeScript God' extension (and any other TS extension until the issue no longer appears).
Stephanos B.
  • 340
Denis Lebon
  • 953
9 Answers9
141
This is because VSCode's Typescript version is not using the newest babel features that create-react-app uses by default.
You can change VS Code to use the workspace's version of Typescript instead, which will fix this issue.
Open a TypeScript or JavaScript file and click on the TypeScript version number in the Status Bar. A message box will appear asking you which version of TypeScript VS Code should use
Select "Use Workspace Version" to use the newer Create React App typescript version.
marksfrancis
  • 1,722
    Seems it was a mix between that and the extension I was using (TypeScript God) that may not be up to date. Anyway, it solved my problem, thanks ! – Denis Lebon Nov 24 '20 at 08:50
    How can I change the workspace version if the project is split into multiple sub-folders? VSCode doesn't seem to pick up `node_modules` in sub directories or at least I don't see other versions available – Narigo Nov 30 '20 at 14:44
  • @Narigo I installed the version I wanted globally (`npm i -g [email protected]`) then added this line to vscode settings json file `"typescript.tsdk": "/home/yourusername/.nvm/versions/node/v10.15.1/lib/node_modules/typescript/lib"` Substitute `/home/yourusername/.nvm/versions/node/v10.15.1/lib/node_modules` for your global npm node_modules folder path (find out with `npm root -g`) – S.. Jul 01 '21 at 21:25
  • My VSCode is using an upper version than one from my project, and It still has problems. – SalahAdDin Oct 05 '22 at 11:24
29
In PhpStorm (and the same is probably true for WebStorm) I got it to not complain about "react-jsx" as the value by ticking "Always download the most recent version of schemas" in Remote JSON Schemas.
The option that needs to be ticked
Attila Szeremi
  • 5,235
  • 40
  • 64
  • I believe that the question was regarding vscode .... – Devorein Dec 03 '20 at 18:08
    True, since I myself found this issue searching for PhpStorm, I thought maybe this could help others as well. Also this could help in being a clue regarding vscode that the issue will have something to do with JSON schemas probably being old. – Attila Szeremi Dec 04 '20 at 10:37
    This did help me as I'm using WebStorm. Thank you! – jonraem Feb 01 '21 at 12:39
As mentioned by others, this is an open issue with create-react-app (CRA) script. However, none of the above mentioned solution worked for me. The only solution that works for me is adding the below config in .env file (in project root).
DISABLE_NEW_JSX_TRANSFORM=true
Vijin Paulraj
  • 4,469
  • 39
  • 54
For the ones using VS 2019 I had to install typescript 4.1 for visual studio from here: https://marketplace.visualstudio.com/items?itemName=TypeScriptTeam.TypeScript-41
Then it worked fine by using the new jsx setting in the compilerOptions etc.
Ilias.P
  • 179
I know this can be obvious for the majority but I always forget to use .tsx file extension in React and then I'm hitting my head trying to understand why the JSX code is throwing an error.
So, make sure you are using .tsx extension and NOT .ts !
Eric Aya
  • 69,473
  • 35
  • 181
  • 253
Gass
  • 7,536
  • 37
  • 41
If you are using VS Code and marksfrancis' answer didn't work for you. Maybe you should check your extensions for TypeScript, in my case the extension 'TypeScript God' was the cause I was still having this issue.
Installing JavaScript and TypeScript Nightly extension and reselecting TS version in VSC (when .tsx is opened, click on TS version (right bottom), then "Select TypeScript version" -> "Use VS Code's Version") also works.
(src: https://code.visualstudio.com/docs/typescript/typescript-compiling#_using-typescript-nightly-builds )
KalikDev
  • 111
If you tried updating the typescript version by selecting "Use Workspace Version" in your vscode editor and it still shows the error, try updating the value of the field "jsx" in your .tsconfig file to "preserve".
  • This will enable you to write JSX the old way.
import React from 'react';
function App() {
  return <h1>Hello World</h1>;
  • If you use the value "react-jsx" value, you will have to write react in the new React 17 Transform:
import { jsx as _jsx } from "react/jsx-runtime";
export const helloWorld = () => _jsx("h1", { children: "Hello world" }, void 0);
.tsconfig file reference (per typescript docs): here
new JSX Transform (per react docs): here
-1
for any one it may help, I just restarted VS code. Credit: https://exerror.com/cannot-use-jsx-unless-the-jsx-flag-is-provided/
engr.waqas
  • 375
