my Linux Java application uses bluetooth devices. I use this library in order to communicate with bluez stack : https://github.com/hypfvieh/bluez-dbus.
It worked very well until I added module-info.java to my client code. Suddenly I got this error:
Exception in thread "main" java.lang.UnsatisfiedLinkError: could not load FFI provider jnr.ffi.provider.jffi.Provider at [email protected]/jnr.ffi.provider.InvalidRuntime.newLoadError(InvalidRuntime.java:101) at [email protected]/jnr.ffi.provider.InvalidRuntime.findType(InvalidRuntime.java:42) at [email protected]/jnr.ffi.Struct$NumberField.(Struct.java:872) at [email protected]/jnr.ffi.Struct$Unsigned16.(Struct.java:1240) at [email protected]/jnr.unixsocket.SockAddrUnix$DefaultSockAddrUnix.(SockAddrUnix.java:209) at [email protected]/jnr.unixsocket.SockAddrUnix.create(SockAddrUnix.java:174) at [email protected]/jnr.unixsocket.UnixSocketAddress.(UnixSocketAddress.java:53) at [email protected]/org.freedesktop.dbus.connections.transports.UnixSocketTransport.(UnixSocketTransport.java:32) at [email protected]/org.freedesktop.dbus.connections.transports.TransportFactory.createTransport(TransportFactory.java:37) at [email protected]/org.freedesktop.dbus.connections.AbstractConnection.(AbstractConnection.java:161) at [email protected]/org.freedesktop.dbus.connections.impl.DBusConnection.(DBusConnection.java:334) at [email protected]/org.freedesktop.dbus.connections.impl.DBusConnection.getConnection(DBusConnection.java:149) at [email protected]/org.freedesktop.dbus.connections.impl.DBusConnection.getConnection(DBusConnection.java:169) at [email protected]/org.freedesktop.dbus.connections.impl.DBusConnection.getConnection(DBusConnection.java:219) at [email protected]/org.freedesktop.dbus.connections.impl.DBusConnection.getConnection(DBusConnection.java:184) at [email protected]/com.github.hypfvieh.bluetooth.DeviceManager.createInstance(DeviceManager.java:74) at ...
Caused by: java.lang.UnsatisfiedLinkError: could not get native definition for type POINTER, original error message follows: java.lang.UnsatisfiedLinkError: could not locate stub library in jar file. Tried [jni/x86_64-Linux/libjffi-1.2.so, /jni/x86_64-Linux/libjffi-1.2.so] at [email protected]/com.kenai.jffi.internal.StubLoader.getStubLibraryStream(StubLoader.java:450) at [email protected]/com.kenai.jffi.internal.StubLoader.loadFromJar(StubLoader.java:375) at [email protected]/com.kenai.jffi.internal.StubLoader.load(StubLoader.java:278) at [email protected]/com.kenai.jffi.internal.StubLoader.(StubLoader.java:487) at java.base/java.lang.Class.forName0(Native Method) at java.base/java.lang.Class.forName(Class.java:427) at [email protected]/com.kenai.jffi.Init.load(Init.java:68) at [email protected]/com.kenai.jffi.Foreign$InstanceHolder.getInstanceHolder(Foreign.java:49) at [email protected]/com.kenai.jffi.Foreign$InstanceHolder.(Foreign.java:45) at [email protected]/com.kenai.jffi.Foreign.getInstance(Foreign.java:103) at [email protected]/com.kenai.jffi.Type$Builtin.lookupTypeInfo(Type.java:242) at [email protected]/com.kenai.jffi.Type$Builtin.getTypeInfo(Type.java:237) at [email protected]/com.kenai.jffi.Type.resolveSize(Type.java:155) at [email protected]/com.kenai.jffi.Type.size(Type.java:138) at [email protected]/jnr.ffi.provider.jffi.NativeRuntime$TypeDelegate.size(NativeRuntime.java:178) at [email protected]/jnr.ffi.provider.AbstractRuntime.(AbstractRuntime.java:48) at [email protected]/jnr.ffi.provider.jffi.NativeRuntime.(NativeRuntime.java:57) at [email protected]/jnr.ffi.provider.jffi.NativeRuntime.(NativeRuntime.java:41) at [email protected]/jnr.ffi.provider.jffi.NativeRuntime$SingletonHolder.(NativeRuntime.java:53) at [email protected]/jnr.ffi.provider.jffi.NativeRuntime.getInstance(NativeRuntime.java:49) at [email protected]/jnr.ffi.provider.jffi.Provider.(Provider.java:29) at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500) at java.base/java.lang.reflect.ReflectAccess.newInstance(ReflectAccess.java:124) at java.base/jdk.internal.reflect.ReflectionFactory.newInstance(ReflectionFactory.java:346) at java.base/java.lang.Class.newInstance(Class.java:604) at [email protected]/jnr.ffi.provider.FFIProvider$SystemProviderSingletonHolder.getInstance(FFIProvider.java:68) at [email protected]/jnr.ffi.provider.FFIProvider$SystemProviderSingletonHolder.(FFIProvider.java:57) at [email protected]/jnr.ffi.provider.FFIProvider.getSystemProvider(FFIProvider.java:35) at [email protected]/jnr.ffi.Runtime$SingletonHolder.(Runtime.java:82) at [email protected]/jnr.ffi.Runtime.getSystemRuntime(Runtime.java:67) at [email protected]/jnr.unixsocket.SockAddrUnix.(SockAddrUnix.java:46) at [email protected]/jnr.unixsocket.SockAddrUnix$DefaultSockAddrUnix.(SockAddrUnix.java:208) at [email protected]/jnr.unixsocket.SockAddrUnix.create(SockAddrUnix.java:174) at [email protected]/jnr.unixsocket.UnixSocketAddress.(UnixSocketAddress.java:53) at [email protected]/org.freedesktop.dbus.connections.transports.UnixSocketTransport.(UnixSocketTransport.java:32) at ...
I tried to require everything related to this error in the module-info.java without success:
module org.example {
    requires dbus.java;
    requires dbus.java.nativefd;
    requires bluecove.linux.custom;
    requires bluez.dbus;
    requires jnr.ffi;
    requires jnr.x86asm;
    requires jnr.posix;
    requires jnr.enxio;
    requires jnr.unixsocket;
    requires jnr.constants;
    requires jnr.a64asm;
Thank you in advance.
VladRia
  • 1,475
  • 32
TL;DR
This worked for me…
java --patch-module jffi={{your.own.location}}/com/github/jnr/jffi/1.3.0/jffi-1.3.0-native.jar …
The long version
I downloaded this example project. It's not a JPMS project. But I added module-info.java files to each of the four sub-projects.
I updated the project's com.github.jnr:jnr-ffi dependency from 2.0.9 to 2.1.5 to match the version I see in your stack trace. And I added the following dependencies…
<dependency>
    <groupId>com.github.hypfvieh</groupId>
    <artifactId>dbus-java</artifactId>
    <version>3.2.3</version>
</dependency>
<dependency>
    <groupId>com.github.hypfvieh</groupId> <artifactId>bluez-dbus</artifactId>
    <version>0.1.3</version>
</dependency>
<dependency>
    <groupId>com.rm5248</groupId>
    <artifactId>dbus-java-nativefd</artifactId>
    <version>1.0</version>
</dependency>
Those were added so that I could then define each one of my four module-info.java descriptors to be pretty much exactly like yours…
module get.pid{
    exports getpid;
    requires dbus.java;
    requires jnr.ffi;
    requires jffi;
    requires jnr.posix;
    requires jnr.enxio;
Before I did the --patch-module, I ran one of the example projects and got the exact same error you got.
But with the following command, all the example applications ran perfectly fine as modules…
java --patch-module jffi={{your.own.location}}/com/github/jnr/jffi/1.3.0/jffi-1.3.0-native.jar --add-modules org.objectweb.asm --add-exports org.objectweb.asm/org.objectweb.asm=jnr.ffi --add-exports org.objectweb.asm/org.objectweb.asm.signature=jnr.ffi --module-path {{path.to.all.the.jars}} -m get.pid/getpid.Getpid
The add-modules and add-exports are crucial too. So don't leave those out.
deduper
  • 1,944
  • 22
