I am trying to create the absolute basic new vue-cli project, on Linux. The generated project won't run. What am I doing wrong?
I installed the most recent vue cli
sudo npm install -g @vue/[email protected]
I created a new project:
cd /tmp
vue create project1
I selected the default presets.
I tried to run the project
$ cd project1
$ npm run serve
> [email protected] serve /tmp/project1
> vue-cli-service serve
 INFO  Starting development server...
 ERROR  Error: Cannot find module 'babel-code-frame'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Module.require (internal/modules/cjs/loader.js:692:17)
    at require (internal/modules/cjs/helpers.js:25:18)
    at Object.<anonymous> (/usr/share/nodejs/eslint/lib/formatters/codeframe.js:8:19)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at exports.loadModule (/tmp/project1/node_modules/@vue/cli-shared-utils/lib/module.js:79:14)
    at api.chainWebpack.webpackConfig (/tmp/project1/node_modules/@vue/cli-plugin-eslint/index.js:59:26)
    at webpackChainFns.forEach.fn (/tmp/project1/node_modules/@vue/cli-service/lib/Service.js:236:40)
    at Array.forEach (<anonymous>)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] serve: `vue-cli-service serve`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] serve script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /home/kevin/.npm/_logs/2020-07-24T17_38_02_618Z-debug.log
My npm version is 6.14.7
$ npm --version
6.14.7
This is package.json after manually hacking in "@babel/code-frame" as suggested by Igor.
  "name": "project1",
  "version": "0.1.0",
  "private": true,
  "scripts": {
    "serve": "vue-cli-service serve",
    "build": "vue-cli-service build",
    "lint": "vue-cli-service lint"
  "dependencies": {
    "core-js": "^3.6.5",
    "vue": "^2.6.11"
  "devDependencies": {
    "@babel/code-frame": "^7.10.4",
    "@vue/cli-plugin-babel": "~4.5.0",
    "@vue/cli-plugin-eslint": "~4.5.0",
    "@vue/cli-service": "~4.5.0",
    "babel-eslint": "^10.1.0",
    "eslint": "^6.7.2",
    "eslint-plugin-vue": "^6.2.2",
    "vue-template-compiler": "^2.6.11"
  "eslintConfig": {
    "root": true,
    "env": {
      "node": true
    "extends": [
      "plugin:vue/essential",
      "eslint:recommended"
    "parserOptions": {
      "parser": "babel-eslint"
    "rules": {}
  "browserslist": [
    "> 1%",
    "last 2 versions",
    "not dead"
I tried clearing down npm cache as per this ticket, but it didn't make a difference.
https://stackoverflow.com/questions/42308879/npm-err-code-elifecycle
Kevin Gill
  • 407
  • install it with `npm install --save-dev @babel/code-frame` – Igor Moraru Jul 24 '20 at 18:11
  • Thanks, I tried that, and it makes no difference. This ends up in the devDependencies, but no build. "@babel/code-frame": "^7.10.4". – Kevin Gill Jul 24 '20 at 18:20
  • uninstall vue cli with: `sudo npm uninstall -g @vue/[email protected]`, then install again with `npm install -g @vue/cli`. NO SUDO. you should not install npm packages with sudo. then create the project again as usual – Igor Moraru Jul 24 '20 at 18:52
  • I created a new virtualbox vm using Ubuntu 20.04. I ran the same commands (including with the sudo), and everything worked OK, so my conclusion is that there is something wrong on my PC, rather than wrong with NPM/VUE. I am going to see if I can mark this question as invalid. – Kevin Gill Jul 24 '20 at 20:01
I removed and reinstalled nodejs and npm to solve the problem.
sudo apt-get remove npm
sudo apt-get remove nodejs
Re-install
sudo apt-get update
sudo apt-get install nodejs npm
Kevin Gill
  • 407
