I am using myeclipse 7, where i have added java EE 5 libraries witch i required.If i add the mail.jar externally to the application, it calling the javaee.jar from java EE 5 libraries.It's not using the mail.jar.If i remove java EE 5 libraries then it is working, But i require java EE 5 libraries. How can i send mail using javaee.jar of java EE 5 library?.
If it require below is my hava code for sed mail
String d_email = "[email protected]",
d_password = "pass",
d_host = "smtp.gmail.com",
d_port = "465",
m_to = "[email protected]",
m_subject = "Testing",
m_text = "This is the testing email.";
public Main()
Properties props = new Properties();
props.put("mail.smtp.user", d_email);
props.put("mail.smtp.host", d_host);
props.put("mail.smtp.port", d_port);
props.put("mail.smtp.starttls.enable","true");
props.put("mail.smtp.auth", "true");
props.put("mail.smtp.debug", "true");
props.put("mail.smtp.socketFactory.port", d_port);
props.put("mail.smtp.socketFactory.class", "javax.net.ssl.SSLSocketFactory");
props.put("mail.smtp.socketFactory.fallback", "false");
SecurityManager security = System.getSecurityManager();
try
Authenticator auth = new SMTPAuthenticator();
Session session = Session.getInstance(props, auth);
session.setDebug(true);
MimeMessage msg = new MimeMessage(session);
msg.setText(m_text);
msg.setSubject(m_subject);
msg.setFrom(new InternetAddress(d_email));
msg.addRecipient(Message.RecipientType.TO, new InternetAddress(m_to));
Transport.send(msg);
System.out.println("Mail Sent");
catch (Exception mex)
mex.printStackTrace();
public static void main(String[] args)
Main blah = new Main();
private class SMTPAuthenticator extends javax.mail.Authenticator
public PasswordAuthentication getPasswordAuthentication()
return new PasswordAuthentication(d_email, d_password);
Error :
Exception in thread "main" java.lang.NoClassDefFoundError: com/sun/mail/util/LineInputStream
at javax.mail.Session.loadProvidersFromStream(Session.java:928)
at javax.mail.Session.access$000(Session.java:174)
at javax.mail.Session$1.load(Session.java:870)
at javax.mail.Session.loadResource(Session.java:1084)
at javax.mail.Session.loadProviders(Session.java:889)
at javax.mail.Session.<init>(Session.java:210)
at javax.mail.Session.getInstance(Session.java:232)
at com.ctn.origin.connection.Main.<init>(Main.java:35)
at com.ctn.origin.connection.Main.main(Main.java:55)
