102
I am getting errors similar to the ones in these questions, except mine are occuring on Heroku:
2011-05-30T09:03:29+00:00 heroku[worker.1]: Starting process with command: `rake jobs:work`
2011-05-30T09:03:30+00:00 app[worker.1]: (in /app)
2011-05-30T09:03:30+00:00 heroku[worker.1]: State changed from starting to up
2011-05-30T09:03:33+00:00 app[worker.1]: rake aborted!
2011-05-30T09:03:33+00:00 app[worker.1]: uninitialized constant Rake::DSL
2011-05-30T09:03:33+00:00 app[worker.1]: /app/.bundle/gems/ruby/1.9.1/gems/rake-0.9.0/lib/rake/tasklib.rb:8:in `<class:TaskLib>'
The answer in those questions seems to be to specify gem 'rake', '0.8.7' because the 0.9 version causes the problem.
When I try to add gem 'rake', '0.8.7' to my gemfile and push to Heroku I get this error:
Unresolved dependencies detected; Installing...
You have modified your Gemfile in development but did not check
the resulting snapshot (Gemfile.lock) into version control
You have added to the Gemfile:
* rake (= 0.8.7)
FAILED: http://devcenter.heroku.com/articles/bundler
! Heroku push rejected, failed to install gems via Bundler
error: hooks/pre-receive exited with error code 1
To [email protected]:my_app.git
! [remote rejected] master -> master (pre-receive hook declined)
error: failed to push some refs to '[email protected]:my_app.git'
My gemfile normally works fine on Heroku. What should I do?
Community
ben
  • 29,229
  • 42
  • 124
  • 179
  • Did you try the [#3 answer](http://stackoverflow.com/questions/5287121/undefined-method-task-using-rake-0-9-0/5290331#5290331) you posted? What happened after making those changes? – Zabba May 31 '11 at 00:31
5 Answers5
205
Put this in your Rakefile above require 'rake':
require 'rake/dsl_definition'
Kale
  • 2,074
    Thank you. That fixed my problems and I didn't know what was going on. (Using the rails installer on windows and deploying to heroku, as a complete beginner.) – Jack V. Jun 14 '11 at 22:46
    does this solution work on windows because i am still getting the same error - uninitialized constant Rake::DSL – David Jun 20 '11 at 08:05
    I got the error deploying to Heroku, which today pulled in rake 0.9.2. Since the original issue was with 0.9.0, maybe the rake version is no longer the problem. Adding the `require` line to the rakefile (and recommitting and re-pushing to github and Heroku) solved it. @David, I'm using Windows with the RoR framework from RailInstaller 1.2.0. – Mark Berry Jun 23 '11 at 01:42
  • Well you'll need to update to rake 0.9.2 for this to work. Good luck! – RubyFanatic Nov 09 '11 at 21:25
  • I get this error when doing rake db:create, "no such file to load -- rake/dsl_definition" – KMC Sep 20 '12 at 03:19
Any time you change your Gemfile, you need to bundle install to update your lockfile (Gemfile.lock). The error you're getting on push is not specific to changing the version of rake.
bundle install
git commit -a -m "update lockfile"
git push heroku master
Note the error message you received:
You have modified your Gemfile in development but did not check the resulting snapshot (Gemfile.lock) into version control
wuputah
  • 11,285
  • 43
  • 60
I solved this, finally, after a lot of mucking about. The short version of what I did, missing out the many experiments, was this:
1) change the Gemfile to specify Rake 0.8.7
#in Gemfile
gem "rake", "0.8.7"
2) Take out a hack that I had previously added to Rakefile based on Stack Overflow question Ruby on Rails and Rake problems: uninitialized constant Rake::DSL:
So, my Rakefile is now back to being the standard Rakefile for my app:
# Add your own tasks in files placed in lib/tasks ending in .rake,
# for example lib/tasks/capistrano.rake, and they will automatically be available to Rake.
require File.expand_path('../config/application', __FILE__)
require 'rake'
MyApp::Application.load_tasks
3) Change Heroku to run my app in Ruby 1.9.2:
heroku stack:migrate bamboo-mri-1.9.2 --app myapp
And it seems fine now - the scheduled cron task is running anyway.
EDIT: It did run fine, once, then blew up again next time I pushed something! Arrgh. I think I fixed it now, with the addition of the delayed_job gem, based on the conversation Don't know how to build task jobs:work.
Installing delayed_job doesn't seem like a great solution, but it HAS worked, and I might want to use it sometime I guess, especially with Heroku's once-per-hour cron job (which just isn't frequent enough - there are things I'll probably want to run every five minutes). After I installed the delayed_job gem I had to do the setup for it, otherwise Heroku complains about the missing delayed_jobs table:
#add to gemfile
gem 'delayed_job'
#at command line
bundle install
rails g delayed_job
rake db:migrate
git add -A
git commit -a -m "added delayed_job gem"
git push
heroku rake db:migrate --app myapp
heroku restart --app myapp
Community
Max Williams
  • 32,435
  • 130
  • 197
I had a Rails 3.0.11 app, which specified rake version 0.8.7 in the Gemfile to get around the version 0.9.2 Rake::DSL problem.
After I converted the app to Rails 3.2.0 (Heroku Cedar stack), I was having a problem with the worker (a rake task) crashing. I changed "gem 'rake', '0.8.7'" to "gem 'rake'", which bundled rake version 0.9.2.2. The worker stopped crashing with the new version.
Wes
Your problem is caused by not deleting the Gemfile.lock file and is not specific to Heroku. Deleting Gemfile.lock should fix this problem, but will lead you straight to another one:
To [email protected]:tailored-landing-pages.git
 * [new branch]      master -> master
manfred@painstation2:~/Desktop/projects/ror/ta/tlp307$ heroku rake db:migrate
rake aborted!
/app/Rakefile:13:in `<class:Application>'
/app/Rakefile:12:in `<module:Tlp307>'
/app/Rakefile:11:in `<top (required)>'
/usr/ruby1.9.2/lib/ruby/1.9.1/rake.rb:2373:in `load'
/usr/ruby1.9.2/lib/ruby/1.9.1/rake.rb:2373:in `raw_load_rakefile'
/usr/ruby1.9.2/lib/ruby/1.9.1/rake.rb:2007:in `block in load_rakefile'
/usr/ruby1.9.2/lib/ruby/1.9.1/rake.rb:2058:in `standard_exception_handling'
/usr/ruby1.9.2/lib/ruby/1.9.1/rake.rb:2006:in `load_rakefile'
/usr/ruby1.9.2/lib/ruby/1.9.1/rake.rb:1991:in `run'
/usr/ruby1.9.2/bin/rake:31:in `<main>'
Unfortunately, I haven't found the solution for that problem yet, since downgrading Rake to 0.8.7 doesn't seem to work here. If somebody else has an answer, I would appreciate it very much.
Peter Mortensen
  • 30,738
  • 105
  • 131
klaffenboeck
  • 6,297
  • 23
  • 33
