I'm using custom-elements aka web-components within Preact. The problem is that Typescript complains about elements not being defined in JSX.IntrinsicElements
- in this case a check-box
element:
<div className={styles.option}>
<check-box checked={this.prefersDarkTheme} ref={this.svgOptions.darkTheme}/>
<p>Dark theme</p>
</div>
Error message (path omitted):
ERROR in MyComponent.tsx
[tsl] ERROR in MyComponent.tsx(50,29)
TS2339: Property 'check-box' does not exist on type 'JSX.IntrinsicElements'.
I came across the following, unfortunately not working, possible solutions:
- https://stackoverflow.com/a/57449556/7664765 - It's an answer not really realted to the question but it covered my problem
I've tried adding the following to my typings.d.ts
file:
import * as Preact from 'preact';
declare global {
namespace JSX {
interface IntrinsicElements {
'check-box': any; // The 'any' just for testing purposes
My IDE grayed out the import part and IntrinsicElements
which means it's not used (?!) and it didn't worked anyway. I'm still getting the same error message.
- https://stackoverflow.com/a/55424778/7664765 - Also for react, I've tried to "convert" it to preact and I got the same results as for 1.
I've even found a file maintained by google in the squoosh project where they did the following to "polyfill" the support:
In the same folder as the component a
missing-types.d.ts
file with the following content, basically the same setup I have but with aindex.ts
file instead ofcheck-bock.ts
and they're using an older TS versionv3.5.3
declare namespace JSX {
'range-input': HTMLAttributes;
I'm assuming their build didn't fail so how does it work and how do I properly define custom-elements to use them within preact / react components?
I'm currently using [email protected]
and [email protected]
