I have one dataframe that contain column email and other columns.
I need to send this data to corresponding email, for example line 0 need to be emailed to [email protected], line 1 need to be emailed to [email protected] and line 2 and 3 need to be send to [email protected]
     Name            Email      Subject CreatedDate     DueDate FinalDeadLine
0    Tony    [email protected]      Renewal  2019-12-15  2019-12-16    2019-12-25
1  Sergio  [email protected]  NewBusiness  2019-11-18  2019-11-22    2019-11-28
2    Nico    [email protected]  Endorsement  2019-12-11  2019-12-13    2019-12-24
3    Nico    [email protected]      Rewrite  2019-12-05  2019-12-07    2019-12-23
Using Splitting dataframe into multiple dataframes I am performing a view on a dataframe:
Example code:
import smtplib
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
import pandas as pd
df = pd.DataFrame({
                'Name': ['Tony','Sergio','Nico','Nico']
                ,'Email': ['[email protected]', '[email protected]','[email protected]','[email protected]']
                ,'Subject':['Renewal', 'NewBusiness', 'Endorsement','Rewrite']
                ,'CreatedDate': ['2019-12-15','2019-11-18','2019-12-11','2019-12-05']
                ,'DueDate': ['2019-12-16','2019-11-22','2019-12-13','2019-12-07']
                ,'FinalDeadLine': ['2019-12-25','2019-11-28','2019-12-24','2019-12-23']
print(df)
# sort the dataframe
# the parameter axis=1 refer to columns, while 0 refers to rows
df.sort_values(by='Email', axis=0, inplace=True)
# set the index to be this and don't drop
df.set_index(keys=['Email'], drop=False,inplace=True)
# get a list of emails
email_list=df['Email'].unique().tolist()
# now we can perform a lookup on a 'view' of the dataframe
nico = df.loc[df.Email=='[email protected]']
# itrating through email_list and printing dataframe corresponding to each email
for e in email_list:
  d = df.loc[df.Email==e]
  #print(d)
But then how can I connect this to my send_mail function?
send_mail function:
user = "[email protected]"
pwd = "mypassword"
subject = "Test subject"
recipients = "[email protected]"
def send_email(user,pwd, recipients, subject):
    try:
        df_html = df.to_html()
        dfPart = MIMEText(df_html,'html')
    #Container
        msg = MIMEMultipart('alternative')
        msg['Subject'] = subject
        msg['From'] = user
        msg['To'] = ",".join(recipients)
        msg.attach(dfPart)
        server = smtplib.SMTP('smtp.gmail.com: 587')
        server.starttls()
        server.login(user, pwd)
        server.sendmail(user, recipients, msg.as_string())
        server.close()
        print("Mail sent succesfully!")
    except Exception as e:
        print(str(e))
        print("Failed to send email")
send_email(user,pwd,recipients,"Test Subject")
Or maybe there is a better and most efficient way of doing all this? Any good examples available online?
Serdia
  • 4,242
  • 22
  • 86
  • 159
So once you are done with the manipulation of the dataframe.. you can use the apply function to do row wise manipulation using
axis = 1
an example of this is below..
import pandas as pd
df = pd.DataFrame()
df["A"] = [1,2,3,4,5]
df["B"] = ["A", "B", "C", "D", "E"]
# print (df)
def printA(d):
    print("row A", d["A"], "row B", d["B"])
df.apply(lambda x:printA(x), axis=1)
row A 1 row B A
row A 2 row B B
row A 3 row B C
row A 4 row B D
row A 5 row B E
coming to your code. modify the email function to accept a row as the input.
would change to
def send_email(dataFrameRow):
then inside that function you can access each of the columns using the same columns names ..
dataFrameRow["Name"] , dataFrameRow["Subject"], dataFrameRow["Email"]
calling the function would be as simple as.. you can call this after sorting or after the set_index.. I am not really sure what your trying to achieve there.. but this should work for your code.
df.apply(lambda x: send_email(x), axis=1)
Yatish Kadam
  • 454
from email.mime.application import MIMEApplication
from email.mime.base import MIMEBase
from email import encoders
from smtplib import SMTP
import smtplib
import sys
import pandas as pd
df = pd.DataFrame({
print(df)
    d.to_csv('Test.csv')
    email_user = '[email protected]'
    email_password = 'XXXXXXXXXX'
    col_one_list = [e]
    recipients = col_one_list
    emaillist = [elem.strip().split(',') for elem in recipients]
    msg = MIMEMultipart()
    msg['Subject'] = 'Test'
    msg['From'] = '[email protected]'
    filename = "Test.csv"
    attachment = open("Test.csv","rb")
    part = MIMEBase('application', 'octet-stream')
    part.set_payload((attachment).read())
    encoders.encode_base64(part)
    part.add_header('Content-Disposition',"attachment; filename=%s" % filename)
    msg.attach(part)
    server.starttls()
    server.login(email_user,email_password)
    server.sendmail(msg['From'], emaillist , msg.as_string())
    server.quit()
print('Done')
