I installed the Ruby EE as my system-wide Ruby.
I added:
bash < <(curl -s https://rvm.beginrescueend.com/install/rvm)
at the end of /etc/profile.
if [ -s "/usr/local/rvm/scripts/rvm" ] ; then
. "/usr/local/rvm/scripts/rvm"
fi
then
rvm install ree
rvm --default ree
I did my logoff and login, and I'm able to check ruby -v
, and it's right, ree is my default Ruby.
The problem is, I install my gems, e.g gem install bundle
, and then try to run bundler and it is not found. If I run the command one more time, rvm use ree
, then I'm able to run bundler.
My RVM info:
web:~# rvm info
system:
system:
uname: "Linux web 2.6.18-238.9.1.el5.028stab089.1 #1 SMP Thu Apr 14 14:06:01 MSD 2011 x86_64 GNU/Linux"
bash: "/bin/bash => GNU bash, version 4.1.5(1)-release (x86_64-pc-linux-gnu)"
zsh: " => not installed"
rvm:
version: "rvm 1.6.5 by Wayne E. Seguin ([email protected])[https://rvm.beginrescueend.com/]"
homes:
gem: "not set"
ruby: "not set"
binaries:
ruby: "/usr/local/rvm/bin/ruby"
irb: "/usr/local/rvm/bin/irb"
gem: "/usr/local/rvm/bin/gem"
rake: "/usr/local/rvm/bin/rake"
environment:
PATH: "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/rvm/bin:/usr/local/rvm/bin"
GEM_HOME: ""
GEM_PATH: ""
MY_RUBY_HOME: ""
IRBRC: ""
RUBYOPT: ""
gemset: ""
added extra infos
web:~# rvm list
rvm rubies
ree-1.8.7-2011.03 [ x86_64 ]
web:~# id
uid=0(root) gid=0(root) groups=0(root)
web:~# gem list | grep bundle
bundler (1.0.12)
web:~# gem list | grep bundler
bundler (1.0.12)
web:~# bundle
-bash: bundle: command not found
web:~# ruby -v
ruby 1.8.7 (2011-02-18 patchlevel 334) [x86_64-linux], MBARI 0x6770, Ruby Enterprise Edition 2011.03
web:~#
