Given the following SSH urls:
[email protected]:james/example
[email protected]:007/example
[email protected]:22/james/example
[email protected]:22/007/example
How can I pull the following:
{user}@{host}:{optional port}{path (user/repo)}
As you can see in the example, one of the usernames is numeric and NOT a port. I can't figure out how to workaround that. A port isn't always in the URL too.
My current regex is:
^(?P<user>[^@]+)@(?P<host>[^:\s]+)?:(?:(?P<port>\d{1,5})\/)?(?P<path>[^\\].*)$
Not sure what else to try.
ThatGuy343
  • 2,354
  • 30
  • 55
Lazy quantifiers to the rescue!
This seems to work well and satisfies the optional port:
(?P<user>.*?)@
(?P<host>.*?):
(?:(?P<port>.*?)/)?
(?P<path>.*?/.*?)
The line breaks are not part of the regex because the /x modifier is enabled. Remove all line breaks if you are not using /x.
https://regex101.com/r/wdE30O/5
Thank you @Jan for the optimizations.
MonkeyZeus
  • 20,375
  • 36
  • 77
  • @ThatGuy343 correct, `007` comes after the colon `:` – MonkeyZeus Aug 28 '19 at 19:07
  • @ThatGuy343 if `007` is not the port then which capture group should contain it? Should that entry be ignored altogether since it is "invalid"? My goal was to create a simple parser, not a validator – MonkeyZeus Aug 28 '19 at 19:08
  • 007 is a username, and part of the path. the path group is like this: `username/repo` – ThatGuy343 Aug 28 '19 at 19:09
  • @ThatGuy343 Now I am even more confused. Please edit your question and mark the expected user, host, port, and path captures from each example you've listed. – MonkeyZeus Aug 28 '19 at 19:11
  • @ThatGuy343 so the colon is always guaranteed? – MonkeyZeus Aug 28 '19 at 19:21
    @MonkeyZeus +1 I think you are close, but what if [email protected]:22/james ... It will match path as 22/james, when should just be james I believe... – vs97 Aug 28 '19 at 19:35
  • @vs97 my intent was to build a dumb parser, not validator. OP's question is still hazy at best until they can expand upon it per my request. Also, your example doesn't seem to fit any of theirs – MonkeyZeus Aug 28 '19 at 19:41
    Really great work man, thank you for this. The trailing slash is included in the match but this small tweaked version fixes that: `^(?P.*?)@(?P.*?):(?:(?:(?P.*?)\/)?(?P.*?\/.*?))$` – ThatGuy343 Aug 28 '19 at 20:02
    @MonkeyZeus: +1 but a few optimizations: a) use verbose mode, b) the non-capturing as you're using it now is superfluous and c) get rid of the forward slash for the port. All in all see https://regex101.com/r/wdE30O/5 – Jan Aug 29 '19 at 06:55
  • @Jan Hmm, never thought to make use of `/x` but it really makes a huge legibility difference. I think that trying to do it all in one line contributed to me having the slash in the port ¯\\_(ツ)_/¯ – MonkeyZeus Aug 29 '19 at 11:54
  • @ThatGuy343 Check out the update. Jan made some great suggestions. – MonkeyZeus Aug 29 '19 at 11:56
  • @MonkeyZeus: You're welcome. Indeed, the verbose flag makes the expressions more readable and helps me a lot when debugging code. – Jan Aug 29 '19 at 12:08
  • @ThatGuy343, Your tweaked version didn't quite work for me, as it parses a URI of `v3/ORGANIZATION/PROJECT/REPO` with `v3` as the port when it should be part of the path. Tweaking it from any character to and digit worked for me: `^(?P.*?)@(?P.*?):(?:(?:(?P\d*?)\/)?(?P.*?\/.*?))$` – Casey Nov 01 '22 at 16:08
If you're on Python, you could write your very own parser:
from parsimonious.grammar import Grammar
from parsimonious.nodes import NodeVisitor
data = """[email protected]:james/example
[email protected]:22/007/example"""
class GitVisitor(NodeVisitor):
    grammar = Grammar(
        r"""
        expr        = user at domain colon rest
        user        = word+
        domain      = ~"[^:]+"
        rest        = (port path) / path
        path        = word slash word
        port        = digits slash
        slash       = "/"
        colon       = ":"
        at          = "@"
        digits      = ~"\d+"
        word        = ~"\w+"
    def generic_visit(self, node, visited_children):
        return visited_children or node
    def visit_user(self, node, visited_children):
        return {"user": node.text}
    def visit_domain(self, node, visited_children):
        return {"domain": node.text}
    def visit_rest(self, node, visited_children):
        child = visited_children[0]
        if isinstance(child, list):
            # first branch, port and path
            return {"port": child[0], "path": child[1]}
        else:
            return {"path": child}
    def visit_path(self, node, visited_children):
        return node.text
    def visit_port(self, node, visited_children):
        digits, _ = visited_children
        return digits.text
    def visit_expr(self, node, visited_children):
        out = {}
        _ = [out.update(child) for child in visited_children if isinstance(child, dict)]
        return out
gv = GitVisitor()
for line in data.split("\n"):
    result = gv.parse(line)
    print(result)
Which would yield
{'user': 'git', 'domain': 'github.com', 'path': 'james/example'}
{'user': 'git', 'domain': 'github.com', 'path': '007/example'}
{'user': 'git', 'domain': 'github.com', 'port': '22', 'path': 'james/example'}
{'user': 'git', 'domain': 'github.com', 'port': '22', 'path': '007/example'}
A parser allows for some ambiguity which you obviously have here.
Jan
  • 42,290
  • 54
  • 79
    You know, I started participating in the regex tag a little over 2 months ago to improve my skills and I feel like I've made good progress; not sure if I am an expert but at least regex doesn't seem overwhelmingly cryptic anymore (I owe most of this to using regex visualizers). Never did I think that I would get into parsers but your post is so nonchalantly "meh, try this parser" that this might be my next adventure, lol – MonkeyZeus Aug 29 '19 at 12:15
  • @MonkeyZeus: Glad to have another traveler here. A good starting point is https://tomassetti.me/guide-parsing-algorithms-terminology/ for a general overview and https://github.com/erikrose/parsimonious for a PEG parser in `Python`. It really widens the possibilities. – Jan Aug 29 '19 at 13:12
    @MonkeyZeus: Shameless self-advertisement: you could very well combine both regular expressions and a parser to have the best of both worlds, see https://stackoverflow.com/a/57749422/1231450 – Jan Sep 02 '19 at 06:20
Here's another regex that handles IP addresses:
((?P<user>.*?)@)?
(?P<host>.*?)
(:(?P<port>.*?))?
(/(?P<path>.*))?
Test vectors:
104.171.200.112
104.171.200.112:22
[email protected]
[email protected]:22/test
104.171.200.112:22/test
104.171.200.112/test/
https://regex101.com/r/G0Arqw/1
driedler
  • 3,750
  • 33
  • 26
