Say I do the following:
>>> a = [email protected]
>>> uname, domain = a.split('@')
But what if I only ever want domain, and never uname? For example, if I only ever wanted uname and not domain, I could do this:
>>> uname, = a.split('@')
Is there a better way to split a into a tuple and have it throw away uname?
john
  • 3,043
  • 27
  • 48
5 Answers5
13
To take into account some of the other answers, you have the following options:
If you know that the string will have an '@' symbol in it then you can simply do the following:
>>> domain = a.split('@')[1]
If there is a chance that you don't have an '@' symbol, then one of the following is suggested:
>>> domain = a.partition('@')[2]
Or
try:
except IndexError:
    print "Oops! No @ symbols exist!"
josh-fuggle
  • 3,097
  • 26
  • 27
  • There's a reason why split and partition both exist. Sometimes split is the right thing to use, but this is not one of those times. – John La Rooy Apr 21 '11 at 10:32
    Can you please explain when to use split and when to use partition? – john Apr 21 '11 at 21:40
You could use your own coding style and specify something like "use '_' as don't care for variables whose value you want to ignore". This is a general practice in other languages like Erlang.
Then, you could just do:
uname, _ = a.split('@')
And according to the rules you set out, the value in the _ variable is to be ignored. As long as you consistently apply the rule, you should be OK.
João Neves
  • 937
  • This use of `_` is actually quite well established, see [What is the purpose of the single underscore “_” variable in Python?](http://stackoverflow.com/q/5893163/699305). – alexis Mar 14 '17 at 13:09
This gives you an empty string if there's no @:
If you want to get the original string back when there's no @, use this:
    >>> domain = a.rpartition('@')[2]
sjcrowe
  • 41
If you know there's always an @ in your string, domain = a.split('@')[1] is the way to go. Otherwise check for it first or add a try..except IndexError block aroudn it.
ThiefMaster
  • 310,957
  • 84
  • 592
  • 636
    You might also consider `domain = a.partition('@')[2]`. This will set `domain` to `''` if there is no `@` in the string, and will also only split on the first `@` if there is more than one. – Karl Knechtel Apr 21 '11 at 10:16
This could work:
domain = a[a.index("@") + 1:]
Rumple Stiltskin
  • 9,597
  • 25
