117
I am trying to clone a project from gitlab to my local machine. I have been granted rights as a developer, and use the command 'git clone
  • None of the protocols work (ssh and https neither work)
The error message I am getting:
remote: The project you were looking for could not be found.
fatal: repository 'https://gitlab.com/KZA_Connected/skilltree.git/' not found
Any help would be highly appreciated.
flaxel
  • 4,173
  • 30
tijnster
  • 1,387
24 Answers24
174
I solved this by simply adding username to url like below,
before: https://gitlab.com/gitlab_user/myrepo.git
after: https://[email protected]/gitlab_user/myrepo.git
Abdul Karim Khan
  • 4,256
  • 26
  • 30
58
Today, I was having the same issue. The repo was working fine at my home machine, but when I tried the same repo in other machine I started facing the same error. I was using below URL
https://gitlab.com/{gitlab_user}/project_repo.git
And now I changed above URL to below
https://{gitlab_user}@gitlab.com/gitlab_user/project_repo.git
And it worked for me. Above solution was found at below URL
https://medium.com/@imstudio/gitlab-the-project-you-were-looking-for-could-not-be-found-issue-685944aa5485
Hope this helps other.
Abdul Waheed
  • 4,540
  • 35
  • 58
52
I have two gitlab accounts. For both I use ssh keys. Both are hosted by gitlab (not self-hosted).
When you run
ssh -T [email protected]
It will return your username.
Welcome to GitLab, @username1!
I was using ssh for @username1 and @username2. It defaults to the first ssh found. So, AFAIK, it's impossible to have two accounts with ssh.
My solution was to rm ssh key from the gitlab account I am not using.
Tom Wojcik
  • 5,471
  • 32
  • 44
    +1 because this might help in the case of a multiple gitlab users conflict, I have read about that elsewhere, and this is likely a good workaround, without having tested it, though. – questionto42 Mar 11 '21 at 21:47
    You can set up hostname aliases to use the keys with different accounts, see https://gist.github.com/oanhnn/80a89405ab9023894df7 – Eliot Sep 21 '21 at 20:58
    Further to Eliot's comment covering using aliases on GitHub, a similar thing is possible on GitLab. After assigning aliases in the ssh config (`Host USERNAME.gitlab.com`), you can then eg. clone with `[email protected]:REPO_OWNER/REPO.git` See: https://docs.gitlab.com/ee/ssh/ – Mina Jan 13 '22 at 19:41
  • I just added my other gitlab account as a collaborator and it works perfectly fine for me under my circumstances – ansakoy Oct 02 '22 at 11:33
    that's great answer that helped me to understand the issue. – Sarvar Nishonboyev Dec 19 '22 at 07:01
30
On mac osx, it usually means that your ssh credentials are not loaded. Brute force solution:
cd ~/.ssh
ssh-add *
I have to do this every time my Macbook reboots.
user3278073
  • 421
Simple Answer: Reset your already existing origin using the following command.
git remote set-url origin https://[email protected]/some-group/project.git
For you it's,
git remote set-url origin https://[email protected]/KZA_Connected/skilltree.git
git remote -v (To check if the changes are reflected), then
git push origin master
Finished.
If it's the first time after the git init
Then
git remote add origin https://[email protected]/gitlabUsername/project_repo.git
Because git remote add origin https://gitlab.com/gitlabUsername/project_repo.git will not work, use the above instead.
If still you get the error, then Remove remote origin by the following and add a new one again
git remote remove origin
Manu R S
  • 872
I solved the above problem
Before: https://gitlab.com/gitlab_user/myrepo.git
After: https://<gitlabusername>@gitlab.com/gitlab_user/myrepo.git
Explanation:
Type your gitlabUsername in place of <gitlabusername>.
Now, it will ask for gitlab password for that your account. Enter the correct password and the project will be cloned successfully.
Ashish Gupta
  • 211
There is credential manager on windows, which contains details about credentials of your host here is s.s of credential manager enter image description here
  1. First of all make sure you have same user credentials which have access to repository which you are trying to clone. If you have correct credentials
then try this url formatter
https://{username}@gitlab.com/username/repo-name.git
in your case it will be like this
'https://[email protected]/KZA_Connected/skilltree.git/'
i was able to solve my problem deleting my credentials and adding them again i hope this help others too
-- Important note this credential manager save your global credentials, you can set your local credentials too using git config
git config --local user.name "Your name"
git config --local user.email "Your email"
git config --local credential.helper "store"
if you set credential.helper to store, in current local git scope it will ask you password every time you do action like pull, push etc
if you want to reset credential.helper, then simply set it back to manager it will work fine as before
Hanzla Habib
  • 3,457
  • 25
  • 25
13
If you (like me) have added multiple ssh keys, the solution is to explicitly state which key should be used for a remote host.
Add the following lines to the ~/.ssh/config file, depending on your use case:
Host bitbucket.org
User git
IdentityFile ~/.ssh/id_rsa
Host gitlab.com
User git
IdentityFile ~/.ssh/id_ed25519
Samuel Olwe
  • 131
  • I have mulitple ssh keys as well, and this was not enough. For me it was also needed to also run 'ssh-add ~/.ssh/', after which the different keys could be found. – Romano Vacca Sep 05 '21 at 15:03
  • Yes, 'ssh-add' is a given, even for a single ssh key. It tells the authentication agent about your keys. – Samuel Olwe Sep 07 '21 at 22:07
12
If adding the ssh key does not work, follow this -
eval "$(ssh-agent -s)"
Then add the ssh key
ssh-add ~/.ssh/<id_rsa>
Ninad Kulkarni
  • 474
First of all verify your credentials are correct.
git config user.email
git config user.name
If they are correct, try appending your username@ before your repo address.
E.g. Instead of
git clone https://repo.abc.com/projectname.git
Try
git clone https://[email protected]/projectname.git
David Buck
  • 3,752
  • 35
  • 35
Vishnu Hari
  • 149
If you are facing the issue for a fresh repo
Just simply change the gitlab default https url from https://gitlab.com/rscodelab/project.git to https://[email protected]/rscodelab/project.git
for example
git clone https://gitlab.com/gitlabusername/project.git
to
git clone https://[email protected]/gitlabusername/project.git
Manu R S
  • 872
Put username before the url like this:
To add git to an existing folder accordingly:
git remote add origin https://[email protected]/projectname.git
skm
  • 559
  • 22
Solution: it was due my windows credentials being set to an other email account.
tijnster
  • 1,387
    incase anyone don't know how to change credentials check this answer https://stackoverflow.com/a/63899445/3946527 – Hanzla Habib Oct 02 '20 at 05:25
In my case, I was not adding .git at the end of URL.
corrected to
This might seem like a silly mistake, but that was it!
Mehul Pamale
  • 349
    Thanks. That was the problem in my case. The push worked fine from a GUI which, presumably, added the `.git` suffix automatically. It did not work from the command line until I've set the url to the `.git` version though. – MarcinKonowalczyk Mar 12 '21 at 23:37
If it's the first time after the git init command, Then use the below command
If still you get the error, then Remove remote origin by the following and retry again by adding the origin using the correct command. to remove origin - git remote remove origin
On Intellij go to
Git->Manage Remotes
then select the url and edit your url to be https://{gitlab_user}@gitlab.com/gitlab_user/project_repo.git
Click Ok. On your password request. You can use your gitlab access token as password if you face authentication challenges.
A.Mushate
  • 395
I was frustrated about this error
Following Steps solved the error(Run All this in terminal)
  1. ssh -T [email protected] Output -> Welcome to GitLab, @username!
  • Go to "Git Bash" just like cmd. Right click and "Run as Administrator". Type ssh-keygen
  • Press enter.
  • It will ask you to save the key to the specific directory. Press enter. It will prompt you to type password or enter without password.
  • The public key will be created to the specific directory.
  • Now go to the directory and open .ssh folder.
  • You'll see a file id_rsa.pub. Open it on notepad. Copy all text from it.
  • Go to https://gitlab.com/-/profile/keys or Paste here in the "key" textfield.
  • Now click on the "Title" below. It will automatically get filled. -Then click "Add key".command
  1. Now You Clone the project using
    git clone https://[email protected]/organization_name/project_name.git
I honestly don't know how GitLab works, I use GitHub, but check if the repo is marked as private.
I had similar issue on GitHub where my friend couldnt retrieve and clone my repo even though he had a status of "Contributor" cz I accidentaly checked it to be Private. Also check if your GitLab account and one you are using in your Command line tool is matching.
if your git --version > 2.10
run the following command in your project repo :
git config --add core.sshCommand "ssh -o IdentitiesOnly=yes -i ~/.ssh/path-to-your-key -F /dev/null"
from this page
joanis
  • 10,635
  • 30
  • 40
Xhyl
I got new account from my company gitlab so I added new ssh key but I got permission issue when tried to clone via ssh.
Then I tried ssh -T [email protected] which returned Welcome to GitLab, @<my_old_account>! I realized I have to remove old ssh keys from .ssh folder. I removed them and it worked.
Sarvar Nishonboyev
  • 12,262
  • 69
  • 70
I tried the above solutions but none work for me. But they helped me in understanding the problem. I had two Gitlab accounts on my new PC.
1 - Remove the Gitlab account in credential Manager Windows.
2 - No need to change the Url of the project.
3 - If you try to push now it will show another error and shows you a pop-up to sign into GitLab.
4 - If you were to sign up using a username/password. The problem will still persist. It will not work. The solution is to sign in through a Web Browser like chrome/edge. It will work. You will be able to push the project.
Rohaitas Tanoli
  • 624
If you are still facing the issue while cloning then try cloning with personal token
git clone https://<username>:<token>@gitlab.example.com/tanuki/awesome_project.git
For more refer this link.
Kartik Garasia
  • 1,324
  • 18
  • 27
I resolved this problem by changing my role on gitlab, before my role was a developer and asked to owner change it to maintiner and this problem solved for me
-3
  • Open a spotlight search.
  • Go to Keychain Access.
  • Search for GitLab.
  • Make sure your account(username) and password match the GitLab credentials for the account you're using to clone the repo.
