Since I am new to the VBA I am trying to structure a code to send email through outlook with the signature.But when I run the below code it displays me only the signature (body does not appear).
When I use "F8" and check it can be clearly seen that my body appears then signature overwrites it.How do I fix this?
Option Explicit
Sub SendEmailwithsign()
Dim objoutApp As Object, objoutmail As Object
Dim strbody As String, strSig As String
Set objoutApp = CreateObject("outlook.Application")
Set objoutmail = objoutApp.CreateItem(0)
On Error Resume Next
With objoutmail
  .To = "[email protected]"
  .CC = ""
  .Subject = "Test mail"
  .Recipients.ResolveAll
  .Display                 'body appears until this point'
  strSig = .Environ("appdata") & "Microsoft\Signatures\bbbb.txt"
  strbody = "Hello"
  .body = strbody & strSig     'with this step Body part does not appear but only the signature'
  End With
   On Error GoTo 0
   Set objoutmail = Nothing
   Set objoutApp = Nothing
End Sub
Cindy Meister
  • 25,071
  • 34
  • 43
Nilusha M.
  • 57
You need to change .body to .HTMLBody, please refer to the below code:
Option Explicit
With objoutmail
  .To = "emailAddress"
  .CC = ""
   strSig = .Environ("appdata") & "Microsoft\Signatures\default.txt"
  strbody = "Hello"
  .HTMLBody = "<p>"+ strbody  +"</p>" & strSig     'with this step Body part does not appear but only the signature'
  End With
   On Error GoTo 0
End Sub
Reference from:
VBA Signature on Email with HTMLBody
Alina Li
  • 884
  • I really appreciate your contribution,but my problem has not been solved yet with the above code.Same incident happens when it goes through ".HTMLBody" part body overwrites the signature and finally remain with only the body.How do I solve this? – Nilusha M. Nov 19 '18 at 08:29
  • Maybe these links will help for you: https://forums.windowssecrets.com/showthread.php/163512-Add-Signature-to-HTML-email-using-VBA https://www.mrexcel.com/forum/excel-questions/358574-add-outlook-signature-using-vba-when-sending-email.html – Alina Li Nov 19 '18 at 09:09
  • Got it.I will try with these links but can I know what is the reason behind that it works in your machine and it does not work my machine? – Nilusha M. Nov 19 '18 at 09:23
  • I'm not sure. Is it possible the environment is diffirent. This is my enviroment: windwo10 64Bit +office2016 professional. – Alina Li Nov 19 '18 at 10:17
