I trained a CNN model on some images following the example of https://blog.keras.io/building-powerful-image-classification-models-using-very-little-data.html. My model code is identical, I just trained it on another image dataset: also for classification between two classes.
The results are what you'd expect on the training set: images are classified correctly either 0 or 1.
I saved the model in a tensorflowjs-friendly format following the "Alternative: Use the Python API to export directly to TF.js Layers format" section of https://js.tensorflow.org/tutorials/import-keras.html
However when I try to access the results in an html page with javascript I get 1 for pretty much every image (or close to it): even if the image gives 0 in Keras.
I have even saved an image as a tensor in JSON and I get 0 in Keras and 1 in TensorflowJS. Is this a bug or have I made a mistake somewhere ?
Here is my code in TensorflowJS to access the json:
<html>
<head>
<!-- Load TensorFlow.js -->
<meta http-equiv="content-type" content="text/html; charset=utf-8" />
<script src="https://cdn.jsdelivr.net/npm/@tensorflow/[email protected]"></script>
<script>
// https://stackoverflow.com/a/18324384/2730032
function callAjax(url, callback){
var xmlhttp;
// compatible with IE7+, Firefox, Chrome, Opera, Safari
xmlhttp = new XMLHttpRequest();
xmlhttp.onreadystatechange = function(){
if (xmlhttp.readyState == 4 && xmlhttp.status == 200){
callback(xmlhttp.responseText);
xmlhttp.open("GET", url, true);
xmlhttp.send();
tf.loadModel('/model.json').then(model => {
callAjax('/tensor.json', res => {
arr = JSON.parse(res);
const example = tf.tensor(arr).reshape([1, 150, 150, 3]);
const prediction = model.predict(example);
prediction.data().then(res => {
console.log('PREDICTION JS', res[0]);
</script>
</head>
<body>
</body>
</html>
And here is my python code for the same:
import json
import numpy as np
import tensorflowjs as tfjs
model = tfjs.converters.load_keras_model('model.json')
with open('tensor.json', 'r') as f:
r = json.load(f)
arr = np.array([np.array([np.array(v) for v in l]) for l in r])
print('PREDICTION PYTHON', model.predict(arr[np.newaxis,...])[0][0])
I get PREDICTION JS 1 and PREDICTION PYTHON 0.0, for exactly the same data and the same model: does anybody see any issue in my code ?
EDIT1: I'm on Xubuntu 18.04.1 LTS and use the following software versions:
Python 3.6.6
Keras 2.2.4
tensorflow 1.11.0
tensorflowjs 0.6.2
numpy 1.15.2
EDIT2: I opened the following issue https://github.com/tensorflow/tfjs/issues/776 and it has since been fixed.
