I have several strings that look like the following:
+H124005992014011/1527399999999I05Z
+H7039700000001/$99999999I051
+K122005962050171/120911234C117
I need each section to be split into its own variable. To do this i thought Regex would be the best way to go.
here are the rules for splitting.
- The first char must be the '+'
- The second section must have an alpha char followed by three digits. i.e. H124, H703, K122
- The third section is a set of alphanumeric chars (1 to 13 chars in length)
- The fourth section is a single decimal digit (0 to 9)
- The fifth section must be the '/' char
- The sixth section is an explicit five digit Julian date code
- The seventh section is a 0 to 13 alphanumeric string
- The eighth section must have an alpha char (A to L) followed by two digits
- and the ninth section is a single alphanumeric char
I have the following Regex pattern which seems to match the strings fine but i am unsure how to turn this full pattern into a string and robust way of splitting these strings....
(^\+)(\D\d\d\d)(\w{1,13})(\d)(\/)(\d{5}|\$)(\w{0,13})\D\d\d\w$
I need to turn the above pattern into a form that will allow me to extract each of the matching sections screens.
Thanks in advance
