I am using DevExpress 18.1 on Windows 10 with VS 2017 for a WPF application. Additionally I am using the DevExpress BarCode Class. I am trying to create a QR Code that is 1 inch in size but am unable to do it without using something like Photoshop to shrink the output. I think I must be missing something in the process. Below is the code being used:
using System.Diagnostics;
using System.Drawing;
using System.Text;
using System.Windows;
using DevExpress.BarCodes;
namespace WpfBarcode01
public partial class MainWindow : Window
public MainWindow()
InitializeComponent();
private void Btn_1_Click(object sender, RoutedEventArgs e)
BarCode barCode = new BarCode();
barCode.Symbology = Symbology.QRCode;
barCode.CodeText =
"Alexander Johnathon Stevenson JR;Senior Software Developer;[email protected];20180709-08:00:00;9993334444;Los Angeles;CA;USA;ABC Company";
barCode.BackColor = Color.White;
barCode.ForeColor = Color.Black;
barCode.RotationAngle = 0;
barCode.CodeBinaryData = Encoding.Default.GetBytes(barCode.CodeText);
barCode.Options.QRCode.Version = QRCodeVersion.Version5;
barCode.Options.QRCode.CompactionMode = QRCodeCompactionMode.Byte;
barCode.Options.QRCode.ErrorLevel = QRCodeErrorLevel.H;
barCode.Options.QRCode.ShowCodeText = false;
barCode.DpiX = 100;
barCode.DpiY = 100;
barCode.AutoSize = false;
barCode.Unit = GraphicsUnit.Millimeter;
barCode.ImageWidth = (float)70;
barCode.ImageHeight = (float)70;
barCode.BarCodeImage.Save("d1.png", System.Drawing.Imaging.ImageFormat.Png);
Process.Start("d1.png");
When this runs, a QR Code is created which a hand held scanner is able to scan both on paper and screen. The problem is it is about 2.76 inches in size. I want one about 1 inch so I end up importing the .png file to Photoshop and reducing the image size to 1 inch. This works as the images now becomes small enough for label or document printing. This workflow though seems too time consuming if someone has to do this for a few hundred QR Codes.
I tried different values for the ImageWidth and ImageHeight as well as different values for DpiX and DPiY but no luck. And I tried to change the GraphicsUnit to Inches but that option does not seem to work as I always get an image of very irregular size. So I ended up using the Millimeter option for GraphicsUnit with a basis that 1 inch = 25.4 millimeters. If I use an ImageWidth or ImageHeight value lower than 65 the QR Code box gets clipped and becomes invalid for scanning.
Is there something else I can do to make the output be 1 inch and still valid? Or perhaps some graphic library call in DevExpress I can call to reduce the .png file to 1 inch like Photoshop does? Thanks in advance.
Update July 9, 2018
Based on PepitoSH's suggested link below I was able to find a solution which I have added here in the code update. This code produces a 1 inch .png QRCode file which is a resize from the original that was 2.76 inches.
using System.Drawing.Drawing2D;
using System.Drawing.Imaging;
using System.Text;
/// <summary>
/// Interaction logic for MainWindow.xaml
/// </summary>
public MainWindow()
barCode.CodeText =
barCode.Dpi = 200;
barCode.AutoSize = false; //needs to be off if specifying unit and widths
barCode.Unit = GraphicsUnit.Millimeter; // Note: 1 inch = 25.4 Millimeters
barCode.ImageWidth = 70F;
barCode.ImageHeight = 70F;
Bitmap bitmap = ResizeImage(barCode.BarCodeImage, 200, 200);
bitmap.Save("QRCode.png");
Process.Start("QRCode.png");
public static Bitmap ResizeImage(Image originalImage, int newWidthInPixels, int newHeightInPixels)
var destRect = new Rectangle(0, 0, newWidthInPixels, newHeightInPixels);
var destImage = new Bitmap(newWidthInPixels, newHeightInPixels);
destImage.SetResolution(originalImage.HorizontalResolution, originalImage.VerticalResolution);
using (var graphics = Graphics.FromImage(destImage))
graphics.CompositingMode = CompositingMode.SourceCopy;
graphics.CompositingQuality = CompositingQuality.HighQuality;
graphics.InterpolationMode = InterpolationMode.HighQualityBicubic;
graphics.SmoothingMode = SmoothingMode.HighQuality;
graphics.PixelOffsetMode = PixelOffsetMode.HighQuality;
using (var wrapMode = new ImageAttributes())
wrapMode.SetWrapMode(WrapMode.TileFlipXY);
graphics.DrawImage(originalImage, destRect, 0, 0, originalImage.Width, originalImage.Height, GraphicsUnit.Pixel, wrapMode);
return destImage;
