I have a pandas data frame gmat. The sample data looks like
YEAR student score mail_id phone Loc
2012 abc 630 [email protected] 1-800-000-000 pqr
2012 pqr 630 [email protected] 1-800-000-000 abc
I would like to iterate through this data frame & create a dataframe from rows of this data frame in for loop & use that data frame for doing calculation.Each iteration in for loop will overwrite previous dataframe with the current row in iteration. For example my first data frame in for loop will look like
and second dataframe after overwriting first row will look like
So I tried following code
for row in gmat.iterrows():
df=pd.DataFrame(list(row))
But while checking I'm seeing df is not populated properly. It's only showing 2 columns Can you please suggest me how to do it?
I also tried this based on Georgy's suggestion, I used for index, row in gmat.iterrows()
. Here I'm getting row as a pd.Series
then I'm using gmrow=pd.DataFrame(row)
But my column heading of original data is coming as row. Data I'm getting as
YEAR 2012
student abc
score 630
mail_id [email protected]
phone 1-800-000-000
Loc pqr
