I am trying to implement "shell script calling expect script" so that it does not prompt the user for entering ssh password every time. I started with Using a variable's value as password for scp, ssh etc. instead of prompting for user input every time and understood that I should have a .sh
file and a .exp
file. I have expect
installed in my system (running expect -v
shows expect version 5.43.0
In my upload-to-server.sh
file I have
cd $SOURCE_PATH/shell
./password.exp $DESTINATION_PATH $SSH_CREDENTIALS $PROJECT_INSTALLATION_PATH $PASSWORD
And in my password.exp
file I have
#!/usr/bin/expect -f
set DESTINATION_PATH [lindex $argv 0];
set SSH_CREDENTIALS [lindex $argv 1];
set PROJECT_INSTALLATION_PATH [lindex $argv 2];
set PASSWORD [lindex $argv 3];
spawn scp $DESTINATION_PATH/exam.tar $SSH_CREDENTIALS':/'$PROJECT_INSTALLATION_PATH
expect "password:"
send $PASSWORD"\n";
interact
On running the upload-to-server.sh
file I get the following error -
./password.exp: line 9: spawn: command not found
couldn't read file "password:": no such file or directory
./password.exp: line 11: send: command not found
./password.exp: line 12: interact: command not found
I arrived at the above code (in the exp file) from multiple sources (without understanding much basics). In one source the code is like this
#!/usr/local/bin/expect
spawn sftp -b cmdFile [email protected]
expect "password:"
send "shhh!\n";
interact
Whereas in another source like this
#!/usr/local/bin/expect -f
set TESTCASE_HOME [lindex $argv 0];
set TESTCASE_LIST [lindex $argv 1];
set timeout 200
spawn $TESTCASE_HOME/dobrt -p $TESTCASE_HOME/$TESTCASE_LIST
expect "*?assword:*" {send -- "$PASSWORD\r";}
expect eof
There are some differences there -
- there is an extra
-f
in the#!/usr/local/bin/expect
line expect "?assword:" {send -- "$PASSWORD\r";} is different from
expect "password:" send "shhh!\n";
interact
replaced withexpect eof
This is my first expect script
so don't have much idea what to code. Any pointers?
Thanks,
Sandeepan
