About database URI format: user name goes before user password, so it should be 'postgresql://someuser:[email protected]/hello'
in your example.
We can pass echo
flag in create_engine
: it is better than setting attribute, moreover it is set to False
by default, so we don't need it at all in particular case.
If you don't want to write your Table
object schema with Column
objects (more info at Describing Databases with MetaData) – just reflect your metadata
and obtain 'people'
table from tables
field of metadata
object.
sessionmaker
is Session
objects factory, not Session
object, so you should use double call (looks ugly) or extract sessionmaker
instance as separate object (in our case we will call it session_factory
AFAIK Session
objects doesn't have method save
, but add
If we want our changes (adding lewis_hamilton
record to table) to be saved we should call commit
method in the end since flush
communicates with database but without committing changes record will be lost (in your case we can work without flush
method calls, you can read more about flush
vs commit
here).
With all these comments something like this should work
from sqlalchemy import *
from sqlalchemy.orm import sessionmaker
from sqlalchemy.orm import mapper
db = create_engine('postgresql://someuser:[email protected]/hello')
metadata = MetaData(db)
# reflecting 'people' table from database schema
metadata.reflect(only=['people'])
people = metadata.tables['people']
class People(object):
pass
people_mapper = mapper(People, people)
session_factory = sessionmaker(bind=db)
db_session = session_factory()
lewis_hamilton = People()
lewis_hamilton.name = 'Lewis'
lewis_hamilton.surname = 'Hamilton'
lewis_hamilton.age = 44
db_session.add(lewis_hamilton)
db_session.commit()
but it will be better (since it is more explicit, second principle) to create people
Table
object using Column
objects instead of reflecting like
people = Table('people', metadata,
Column('id', Integer, primary_key=True),
Column('name', String(60)),
Column('surname', String(60)),
Column('age', SmallInteger))
Also if you want to map class People
with 'people'
table following Object Relational Tutorial we will have something like
from sqlalchemy.ext.declarative import declarative_base
Base = declarative_base(metadata=metadata)
class People(Base):
__table__ = people
or without people
Table
object:
class People(Base):
__tablename__ = 'people'
id = Column('id', Integer, primary_key=True)
name = Column('name', String(60))
surname = Column('surname', String(60))
age = Column('age', SmallInteger)
and we can add __init__
method as well so finally we will have
class People(Base):
def __init__(self, name, surname, age):
self.name = name
self.surname = surname
self.age = age
lewis_hamilton = People(name='Lewis',
surname='Hamilton',
age=44)
db_session.commit()
Further improvements
As said in PEP-8:
Wildcard imports ( from import * ) should be avoided, as they make it unclear which names are present in the namespace, confusing both readers and many automated tools. There is one defensible use case for a wildcard import, which is to republish an internal interface as part of a public API (for example, overwriting a pure Python implementation of an interface with the definitions from an optional accelerator module and exactly which definitions will be overwritten isn't known in advance).
so your line
should be more specific since there are a lot of things inside and you don't need them all.
