Can a single regex be used to valdate urls and match all the parts, I have been working on one and what I have come up with so far is:
(?:(?P<scheme>[a-z]*?)://)?(?:(?P<username>.*?):?(?P<password>.*?)?@)?(?P<hostname>.*?)/(?:(?:(?P<path>.*?)\?)?(?P<file>.*?\.[a-z]{1,6})?(?:(?:(?P<query>.*?)#?)?(?P<fragment>.*?)?)?)?
however this does not work, it should match all of the following examples:
http://username:[email protected]/path?arg=value#anchor
http://www.domain.com/
http://www.doamin.co.uk/
http://www.yahoo.com/
http://www.google.au/
https://username:[email protected]/
ftp://user:[email protected]/path/
https://www.blah1.subdoamin.doamin.tld/
domain.tld/#anchor
doamin.tld/?query=123
domain.co.uk/
domain.tld
http://www.domain.tld/index.php?var1=blah
http://www.domain.tld/path/to/index.ext
mailto://[email protected]
and provide a named capture for all the components:
scheme eg. http https ftp ftps callto mailto and any other one not listed
username
password
hostname including subdomains, domainand tld
path eg /images/profile/
filename eg file.ext
query string eg. ?foo=bar&bar=foo
fragment eg. #anchor
With the hostname as the only mandatory field.
We can assume that this is coming from a form specificly asking for an url, and is not going to be used to find links in text.
Kevin Panko
  • 8,356
  • 50
  • 61
UnkwnTech
  • 88,102
  • 65
  • 184
  • 229
No.
strager's regex is impressive, but at the end of the day it's less readable, maintainable and reliable than just using a proper URI parser. It necessarily rejects valid URIs and accepts strings that are not URIs, because the rules of formatting URIs cannot be fully expressed in a regex.
There shouldn't be a '//' in a mailto URI. You can't tell what format the remainder (post-:) of the URI is going to be until you've read the scheme; many URI schemes do not conform to the credentials@host/path format. Best to accept only specific schemes where you know how to parse their URIs.
bobince
  • 528,062
  • 107
  • 651
  • 834
Modified version of mingfai's regular expression:
/^((?P<scheme>https?|ftp):\/)?\/?((?P<username>.*?)(:(?P<password>.*?)|)@)?(?P<hostname>[^:\/\s]+)(?P<port>:([^\/]*))?(?P<path>(\/\w+)*\/)(?P<filename>[-\w.]+[^#?\s]*)?(?P<query>\?([^#]*))?(?P<fragment>#(.*))?$/
Community
strager
  • 88,763
  • 26
  • 134
  • 176
  • It's got non-greedy matches, so it's guaranteed to accept invalid input: namely extra nonsense at the spot of the non-greedy matches. – Eamon Nerbonne May 31 '11 at 08:27
