I am new in node.js I am using MEAN for my project.In my project I have an option to "Subscribe email" at footer. Because of footer I can't use Angular for flash message (I dont have any controller). Using normal node.js I need to display the flash message.
Here is my code server.js
var express = require('express');
var bodyParser = require('body-parser');
var app = express();
var session = require('express-session');
var flash = require('express-flash-notification')
var cookieParser = require('cookie-parser')
app.use(cookieParser("hash"));
app.use(session({secret:"hash", cookie: { maxAge: 60000 }, resave: true, saveUninitialized: true }))
app.use(bodyParser.urlencoded({extended:true}));
app.use(bodyParser.json());
app.use(express.static('public'));
app.use(flash(app));
app.use(express.static(__dirname + '/client'));
app.use('/admin', express.static(__dirname + '/admin'));
app.use('/', express.static(__dirname + '/client', { redirect: false }));
app.post('/subscribe', function (req, res)
if(req.body.name == '[email protected]')
//return console.log(error);
//res.send(200);
req.flash('info', 'Thank you', 'home')
else
res.send(500);
app.listen(3000, function(){
console.log('server is running on port 3000..');
and html file
<!DOCTYPE html>
<html lang="en">
<body>
<!-- footer -->
<div>
<form action="/subscribe" method="POST">
<input name="name" id="name" type="text" placeholder="Enter your email address" /><input type="submit" name="submit" id="submit" class="newsletter-submit" />
</form>
</div>
</body>
</html>
this shows error "No default engine was specified and no extension was provided".
How to fix this and how I can show message in html page. I have tried
{{info}}
but its not working
Thank you
