When compiling a particular solution in Visual Studio 2015 using IncrediBuild 7.31 it always insist on rebuilding the entire solution even when no files have changed. I only see this behaviour for the solution on a particular (older) branch.
I have used the setting from the answer to VS2010 always thinks project is out of date but nothing has changed: "Tools->Options->Projects and Solutions->Build and Run->MSBuild project build output verbosity": Diagnostic. This gives me output like this:
1>Project not up to date because the following 36 build inputs were missing:
1> up to date is missing: 'C:\PROGRAM FILES (X86)\XOREAX\INCREDIBUILD\MODULECACHE\220C7\11AC8\C1.DLL'
1> up to date is missing: 'C:\PROGRAM FILES (X86)\XOREAX\INCREDIBUILD\MODULECACHE\220C7\11AC8\C1XX.DLL'
1> up to date is missing: 'C:\PROGRAM FILES (X86)\XOREAX\INCREDIBUILD\MODULECACHE\220C7\11AC8\C2.DLL'
1> up to date is missing: 'C:\PROGRAM FILES (X86)\XOREAX\INCREDIBUILD\MODULECACHE\2B0E5\11AC8\C1.DLL'
Does anyone know how I can avoid that the compiler thinks that "Project not up to date"?
Community
nielses
  • 150
Removing the /Bv flag solves the problem for me. (It turns out that a colleague of mine had fixed it in the newer branch.)
I consider it a bug in IncrediBuild.
nielses
  • 150
    Hi nielses, my name is Dori and I'm from the IncrediBuild team. This is the first time we hear about this issue and will appreciate if you could approach our support at [email protected] to receive instructions on how to send us an extended log so we can address the problem you report in a proper manner. Disclaimer - the writer works at IncrediBuild – Dori Mar 22 '17 at 14:42
  • Thank you, but actually my colleague explains that "he sent our diagnostic build log files to Xoreax, and they told him to remove /Bv". So thanks to IncrediBuild support for resolving this. You might have our specifc case in your records. – nielses Mar 22 '17 at 18:25
