I'm trying to pass a parameter into a function, inside of a directive link function, similar to this question: Angular: calling controller function inside a directive link function using &
However, while I've seen a few examples, like this one: Passing Parameters from a Directive to a function and I've seen a parameter value get set inside the link inside a directive. Yet, I've not seen any where you are passing a primitive, like a number in as a parameter to the directive which passes that into the controller function.
I've tried multiple things, but haven't figured out the syntax.
HTML CODE:
<!DOCTYPE html>
<html>
  <head>
    <script data-require="[email protected]" data-semver="1.4.2" src="https://code.angularjs.org/1.4.2/angular.js"></script>
    <link rel="stylesheet" href="style.css" />
    <script src="script.js"></script>
  </head>
  <body>
    <div id="app" ng-app="app">
    <div ng-controller="mainCtrl">
          <my-directive ctrl-fn="ctrlFn(count)"></my-directive>
        </div>
      </div>
  </body>
</html>
SCRIPT.JS
var app = angular.module('app', []);
app.controller("mainCtrl", function($scope) {
  $scope.count = 0;
  $scope.ctrlFn = function() {
      $scope.count = 0;
      console.log('In mainCtrl ctrlFn!');
      $scope.count += count;
     // console.log("count is: " + JSON.stringify($scope.count));
    //Call service here
.directive('myDirective', function() {
  return {
    restrict: 'E',
    scope: {
      'count' : '&',
      'ctrlFn' : '&'
    template: "<div><button ng-click='ctrlFn({count: 10})'>Click Here</button></div>",
    link: function(scope, element, attributes) {
      var count = null;
      scope.ctrlFn = scope.ctrlFn({count: count});
      //scope.text = scope.fn({ count: 0 });
My plunker is here: http://plnkr.co/edit/6uDntNeqe0g343PmeCED?p=preview
Can a primitive get passed in as a parameter in this use case? If so, what am I missing here?
Aftermath:
In case someone is looking for this syntax: ctrlFn({count: 10}) in the angularjs docs, it's mentioned here under custom directives:
Often it's desirable to pass data from the isolate scope via an expression to the parent scope, this can be done by passing a map of local variable names and values into the expression wrapper function. For example, the hideDialog function takes a message to display when the dialog is hidden. This is specified in the directive by calling close({message: 'closing for now'}). Then the local variable message will be available within the on-close expression.
Community
James Drinkard
  • 15,342
  • 114
  • 137
You've made two mistakes:
  • scope.ctrlFn = scope.ctrlFn({count: count}); - this line overrides passed reference to a function and sets it to be value returned by this function (undefined in this case)
  • to pass count value to your direcive you should use = instead of &
Below is code of simplified example.
script.js:
  $scope.count = 0;
  $scope.ctrlFn = function(count) {
      console.log(count)
      console.log('In mainCtrl ctrlFn!', count);
    //Call service here
  return {
    restrict: 'E',
    scope: {
      'count' : '=',
      'ctrlFn' : '&'
    template: "<div><button ng-click='ctrlFn({ count: 100 })'>Click Here</button></div>"
index.html:
<!DOCTYPE html>
<html>
  <head>
  </head>
  <body>
    <div ng-controller="mainCtrl"> {{count}}
        </div>
      </div>
  </body>
</html>
Bartek Fryzowicz
  • 6,464
  • 18
  • 27
    Well I got one thing right, I asked a question on SO. Thank you for the help! – James Drinkard Feb 10 '17 at 20:11
  • I'm glad I could help you. – Bartek Fryzowicz Feb 10 '17 at 20:13
  • I just went through this, so is there a way to keep the count itself out of the directive code and just pass a value, like 100 from the ng-click to the controller without having to put that into the directives link function? I'm trying to make this a component and encapsulate the functionality, but I don't want the directive to know anything about the value itself, just pass it along. I want the value set outside of the directive. – James Drinkard Feb 10 '17 at 20:43
  • Sure, answer updated. Actually you do it correctly in you example. – Bartek Fryzowicz Feb 10 '17 at 20:49
  • I was close, but non-working code is worthless. Thanks for the updated answer! – James Drinkard Feb 10 '17 at 21:16
