When issuing grunt shell:test
, I'm getting warning "the input device is not a TTY" & don't want to have to use -f
$ grunt shell:test
Running "shell:test" (shell) task
Warning: Command failed: /bin/sh -c ./run.sh npm test
Use --force to continue.
Aborted due to warnings.
Here's the Gruntfile.js
command:
shell: {
test: {
command: './run.sh npm test'
Here's run.sh
#!/bin/sh
# should use the latest available image to validate, but not LATEST
if [ -f .env ]; then
RUN_ENV_FILE='--env-file .env'
fi
docker run $RUN_ENV_FILE -it --rm --user node -v "$PWD":/app -w /app yaktor/node:0.39.0 $@
Here's the relevant package.json
scripts
with command test
"scripts": {
"test": "mocha --color=true -R spec test/*.test.js && npm run lint"
How can I get grunt
to make docker
happy with a TTY? Executing ./run.sh npm test
outside of grunt works fine:
$ ./run.sh npm test
> [email protected] test /app
[snip]
105 passing (3s)
> [email protected] lint /app
> standard --verbose
