I have created a navigation drawer,When user click on hamburger icon it opens the drawer. I need to add a close button in drawer. This is what i need to implement.
I have tried, bunt unable to add an image on the Drawer Layout. This is my code to add Navigation Drawer. Kindly guide me how to add an image at the top right corner of Drawer.
<LinearLayout
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:orientation="vertical"
    android:id="@+id/base_layout">
    <include layout="@layout/header_layout"/>
</LinearLayout>
    <android.support.design.widget.NavigationView
        android:layout_width="wrap_content"
        android:id="@+id/navigation_view"
        android:layout_gravity="start"
        android:background="@drawable/sidebg"
        app:menu="@menu/drawer_menu"
        app:itemTextColor= "#ffffff"
        app:headerLayout="@layout/navigation_drawer_header"
        android:gravity="bottom|left"
        android:dividerHeight="0dp"
        app:itemIconTint="@android:color/white"
    </android.support.design.widget.NavigationView>
</android.support.v4.widget.DrawerLayout>
dev90
  • 7,187
  • 80
  • 153
ActionBarDrawerToggle will fix your problem:
mDrawerLayout = (DrawerLayout) findViewById(R.id.drawer_layout);
        mDrawerToggle = new ActionBarDrawerToggle(
                this,                  /* host Activity */
                mDrawerLayout,         /* DrawerLayout object */
                R.drawable.ic_drawer,  /* nav drawer icon to replace 'Up' caret */
                R.string.drawer_open,  /* "open drawer" description */
                R.string.drawer_close  /* "close drawer" description */
            /** Called when a drawer has settled in a completely closed state. */
            public void onDrawerClosed(View view) {
                super.onDrawerClosed(view);
                getActionBar().setTitle(mTitle);
            /** Called when a drawer has settled in a completely open state. */
            public void onDrawerOpened(View drawerView) {
                super.onDrawerOpened(drawerView);
                getActionBar().setTitle(mDrawerTitle);
        // Set the drawer toggle as the DrawerListener
        mDrawerLayout.setDrawerListener(mDrawerToggle);
        getActionBar().setDisplayHomeAsUpEnabled(true);
        getActionBar().setHomeButtonEnabled(true);
Alternative way:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical">
    <android.support.v4.widget.DrawerLayout
        android:layout_height="match_parent">
        <!--your layout here -->
    <ImageView
        android:layout_alignParentRight="true"
        android:layout_alignParentTop="true"
        android:id="@+id/im_close_btn"
        android:layout_width="48dp"
        android:layout_height="48dp"
        android:visibility="gone"
        android:src="@drawable/ic_close"/>
</RelativeLayout>
Amir
  • 16,067
  • 80
  • 119
  • Thanks, but still i am unable to understand that how to add `X` image at the top right corner – dev90 Aug 30 '16 at 19:11
  • If you want to use ActionBarDrawerToggle make it RTL will fix your problem. alternative way is to put a close button in corner and when Drawer Open make it visible. – Amir Aug 30 '16 at 19:14
  • Thanks, let me try the Alternative approach – dev90 Aug 30 '16 at 19:22
  • You're showing the v4 `ActionBarDrawerToggle`, whereas the OP mentions the hamburger icon, which is implemented in the v7 class. Also, the OP states that they want the close `Button` in the drawer, but that's not what your "Alternative way" demonstrates. – Mike M. Aug 30 '16 at 19:33
  • @MikeM. Thanks, As I understood it's drawerLayout put whole screen so He needs a button to close a DrawerLayout so I suggest alternative way. – Amir Aug 30 '16 at 19:35
Add a click listener to the imageview of the X icon.
imageView.setOnClickListener(new View.OnClickListener() {
        @Override
        public void onClick(View view) {
            Drawer.closeDrawer(Gravity.LEFT);
To add the icon you want to do a sort of custom view
android:id="@+id/drawer_layout"
android:layout_height="match_parent" >
<RelativeLayout
    xmlns:tools="http://schemas.android.com/tools"
    android:paddingBottom="@dimen/activity_vertical_margin"
    android:paddingLeft="@dimen/activity_horizontal_margin"
    android:paddingRight="@dimen/activity_horizontal_margin"
    android:paddingTop="@dimen/activity_vertical_margin"
    tools:context=".MainActivity" >
    <TextView
        android:layout_height="wrap_content"
        android:text="android-coding.blogspot.com" />
</RelativeLayout>
<LinearLayout
    android:id="@+id/drawer"
    android:layout_width="200dp"
    android:background="@android:color/background_dark"
    android:padding="5dp" >
    <TextView
        android:text="android-coding"/>
    <ImageView
        android:id="@+id/imageview"
        android:background="yourdrawable"
</LinearLayout>
See My source
Same as your question.
Community
StarWind0
  • 1,554
  • 46
navigation_drawer_header.xml
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    android:layout_height="@dimen/nav_header_height"
    android:background="@drawable/side_nav_bar"
    android:gravity="bottom"
    android:theme="@style/ThemeOverlay.AppCompat.Dark">
    <Button
        android:id="@+id/closeButton"
        android:text="X"
        android:layout_gravity="right"/>
    <ImageView
        android:id="@+id/imageView"
        android:paddingTop="@dimen/nav_header_vertical_spacing"
        app:srcCompat="@android:drawable/sym_def_app_icon" />
    <TextView
        android:text="Android Studio"
        android:textAppearance="@style/TextAppearance.AppCompat.Body1" />
    <TextView
        android:id="@+id/textView"
        android:text="[email protected]" />
</LinearLayout>
Java Code
View headerView = navigationView.getHeaderView(0);
        Button closeButton = (Button) headerView.findViewById(R.id.closeButton);
        closeButton.setOnClickListener(new View.OnClickListener() {
            @Override
                drawer.closeDrawer(Gravity.LEFT);
Muhammad Waleed
  • 2,517
  • 27
  • 75
I believe you want to know how to add the "x" button. Well, Do you see the line below in your NavigationView :
This is the header layout of your drawer. Open this layout and put your ImageView in it. As simple as that.
Faisal
  • 566
