I am trying to compile an interpreter for the J programming language called "unbox" which can be found at: https://github.com/iocane/unbox
It uses the tup build-system and the github instructions specify to use the tup command from the Visual Studio tools prompt. I downloaded Visual Studio 2015 Community but it doesn't come with the exact prompt mentioned in the instructions so I used the VS2015 x86 x64 Cross Tools Command Prompt. After installing tup and adding it to my path, I navigated to the directory where I cloned "unbox" and typed tup.
However, this is where the problems start, after typing tup I get the following:
* 1) CC src/libj\a.c
a.c
*** tup errors ***
tup error: File 'C:\Users\I\AppData\Local\Microsoft\VSCommon\14.0\SQM\VCToolsTelemetry.dat' was written to, but is not in .tup/db. You probably should specify it as an output
*** Command ID=663 ran successfully, but tup failed to save the dependencies.
* 2) CC src/libj\af.c
af.c
*** tup errors ***
*** Command ID=667 ran successfully, but tup failed to save the dependencies.
* 3) CC src/libj\ai.c
ai.c
*** tup errors ***
*** Command ID=669 ran successfully, but tup failed to save the dependencies.
* 4) CC src/libj\ab.c
ab.c
*** tup errors ***
*** Command ID=665 ran successfully, but tup failed to save the dependencies.
[ ETA~=30s Remaining=130 Active=0 ] 2%
*** tup: 4 jobs failed.
As you can see, the file VCToolsTelemetry.dat was not specified in tup's database.
Does anybody know a way to prevent Visual Studio from using VSToolsTelemetry.dat at all? Or should I contact the unbox developer and have him add that file to the db?
Any help is much appreciated.
