I have configured the DynaTrace Endeca plugin and set all it's configurable values including protocol, port, and host. Then I created a Chart and added series for HostReachable measure which show value 1 all the time. Then I added NumOfRequest series but it shows message No measurements available for selected timeframe. How do I capture chart values for this measure. Apart for HostReachable I'm not able to capture any values for other measures.
In "add series" dialog I can see one row in Splitting Value section ([email protected]) only for HostReachable measure. This could be one of the reason but not sure.
Following is latest logs:
2016-08-17 09:55:45 INFO [EndecaMonitor@Prod Endeca Monitor_0] info
2016-08-17 09:55:45 INFO [EndecaMonitor@Prod Endeca Monitor_0] Executing method: , URI: http://abc.xyz.org:12345/admin?op=stats
2016-08-17 09:55:45 INFO [EndecaMonitor@Prod Endeca Monitor_0] Parrsing XML from: http://abc.xyz.org:12345/admin?op=stats
2016-08-17 10:00:45 INFO [EndecaMonitor@Prod Endeca Monitor_0] info
2016-08-17 10:00:45 INFO [EndecaMonitor@Prod Endeca Monitor_0] Executing method: , URI: http://abc.xyz.org:12345/admin?op=stats
2016-08-17 10:00:45 INFO [EndecaMonitor@Prod Endeca Monitor_0] Parrsing XML from: http://abc.xyz.org:12345/admin?op=stats
radimpe
  • 3,197
  • 27
  • 46
Sukhjeevan
  • 3,074
  • 46
  • 89
