I am trying to get a Token with my node.js server.
The code below gets executed when someone calls the REST-API of my server (within the processing of this call the server makes several calls himself).
The following configuration works in POSTMAN:
URL: https://login.windows.net/MyCompanyTenant.onmicrosoft.com/oauth2/token
Header:
  • Cache-Control: no-cache
  • Content-Type: application/x-www-form-urlencoded
Body:
Now My failing Code trying to build this Request:
function retrieveAuthToken() {
    var deferred = q.defer();
    var bodyDataString = querystring.stringify({
        grant_type: "password",
        client_id:  someClientId,
        resource: someUrl,
        username: someUsername,
        password: someUsernamePassword,
        client_secret: someString
   //I also tried replacing thie bodyDataString by the bodyString from the working request provided by Fiddler
    var options = {
        host: 'login.windows.net',
        path: '/someTenant/oauth2/token',
        method: 'POST',
        headers: {
            "Content-Type": "application/x-www-form-urlencoded",
            "Cache-Control": "no-cache"
    var request = https.request(options, function(response){
        var body = '';
        response.on('data', function(d) {
            body += d;
        response.on('end', function() {
            var parsed = JSON.parse(body); //todo: try/catch
            rdeferred.resolve(parsed.access_token);
    request.on('error', function(e) {
        console.log(e.message);
        deferred.reject();
   request.write(bodyDataString );
   return deferred.promise;
I dont see any error, my server just waits and waits...
IntegerWolf
  • 1,232
You're missing a request.end() to finish the request. Or as a shortcut, you can change the single request.write(bodyDataString) to request.end(bodyDataString).
mscdex
  • 104,356
  • 192
  • 153
