In Java, String
class has a method: public String[] split(String regex)
This method accepts a regular expression and splits the string it's called on by this regular expression, returning an array of String
s, the result of the split.
Basically, it has some optimizations for regexes with length of 1, and for the longer regular expressions, it calls just this code:
Pattern.compile(regex).split(this, 0)
So basically, it compiles the regular expression every time the split(String regex)
method is called. But actually, pattern compilation is a relatively costly operation, but a pattern can be used to process (split in this case) multiple strings at different times (also it's immutable and therefore thread safe).
My question is: Why doesn't Java compiler or JVM optimize this somehow, either on compilation or runtime, by (maybe lazy) precompiling the regular expressions of split("regex")
calls? I cannot think of a benefit of compiling a string literal to a pattern over and over. I'm thinking about something similar to String interning, or just keeping an array somewhere for precompiled Pattern
s?
I wrote the following code to observe the difference in performance (Regular Expression and String taken from this answer) (the sample string emails
is the list of emails with SOMETHING
between each of them):
public static final String REGEX = "(?:(?:\\r\\n)?[ \\t])*(?:(?:(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*))*@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*|(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)*\\<(?:(?:\\r\\n)?[ \\t])*(?:@(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*(?:,@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*)*:(?:(?:\\r\\n)?[ \\t])*)?(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*))*@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*\\>(?:(?:\\r\\n)?[ \\t])*)|(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)*:(?:(?:\\r\\n)?[ \\t])*(?:(?:(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*))*@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*|(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)*\\<(?:(?:\\r\\n)?[ \\t])*(?:@(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*(?:,@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*)*:(?:(?:\\r\\n)?[ \\t])*)?(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*))*@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*\\>(?:(?:\\r\\n)?[ \\t])*)(?:,\\s*(?:(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*))*@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*|(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)*\\<(?:(?:\\r\\n)?[ \\t])*(?:@(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*(?:,@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*)*:(?:(?:\\r\\n)?[ \\t])*)?(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\"(?:[^\\\"\\r\\\\]|\\\\.|(?:(?:\\r\\n)?[ \\t]))*\"(?:(?:\\r\\n)?[ \\t])*))*@(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*)(?:\\.(?:(?:\\r\\n)?[ \\t])*(?:[^()<>@,;:\\\\\".\\[\\] \\000-\\031]+(?:(?:(?:\\r\\n)?[ \\t])+|\\Z|(?=[\\[\"()<>@,;:\\\\\".\\[\\]]))|\\[([^\\[\\]\\r\\\\]|\\\\.)*\\](?:(?:\\r\\n)?[ \\t])*))*\\>(?:(?:\\r\\n)?[ \\t])*))*)?;\\s*)";
public static void main(String[] args) {
String emails = "\"Fred Bloggs\"@[email protected] Norris <[email protected]>SOMETHINGwebmaster@mü[email protected]";
long t1 = System.currentTimeMillis();
test1(emails);
System.out.println("Test 1 took " + (System.currentTimeMillis() - t1) + " milliseconds...");
long t2 = System.currentTimeMillis();
test2(emails);
System.out.println("Test 2 took " + (System.currentTimeMillis() - t2) + " milliseconds...");
public static void test1(String input) {
for (int i = 0; i < 100000; i++) {
input.split(REGEX);
public static void test2(String input) {
Pattern pattern = Pattern.compile(REGEX);
pattern.split(input);
And the output is:
Test 1 took 34831 milliseconds...
Test 2 took 11799 milliseconds...
After all, that's a pretty big difference, isn't it?
