I am building a simple restful API using express4, mongoose and body parser as middleware.
Index.js
//base setup
var express = require('express'); // call express
var mailsystem = express(); // define our app using express
var bodyParser = require('body-parser');
var InDb = require('./mailsystem/client/clientsend');
var mangoose = require('mongoose');
var morgan = require('morgan');
mailsystem.use(morgan('dev'));
// require('daemon')();
mangoose.connect('mongodb://abc:[email protected]:31982/mailsystem2');
// configure app to use bodyParser()
// this will let us get the data from a POST
mailsystem.use(bodyParser.urlencoded({
extended: true
mailsystem.use(bodyParser.json());
mailsystem.use(function(req, res, next) {
req.rawBody = '';
req.setEncoding('utf8');
req.on('data', function(chunk) {
req.rawBody += chunk;
req.on('end', function() {
next();
var port = process.env.PORT || 8080; // set our port
// ROUTES FOR OUR API
var router = express.Router(); // get an instance of the express Router
router.use(function(req, res, next) {
console.log('inside route');
next();
router.route('/clietsends')
.post(function(req, res, next) {
//req.rawBody ='';
//req.setEncoding('utf-8');
// var mine;
//var contentType = req.headers['content-type'] || '', mime = contentType.split(';')[0];
var clientsend = new InDb();
//clientsend.name = req.body.name;
clientsend.emailId = req.body.emailId;
clientsend.subject = req.body.subject;
clientsend.message = req.body.message;
var email = clientsend.emailId;
var sub = clientsend.subject;
var mess = clientsend.message;
//Call_mandrill(email, sub, mess);
console.log(req.body);
console.log(req.params);
clientsend.save(function(err) {
if (err)
res.send(err);
else {
req.body += req.rawBody;
//req.rawBody += req.params;
res.json(req.body);
//console.log(req.params);
// res.json({message:'message of post created'})
.get(function(req, res) {
//need not to initiliaze again
/*var clientsend = new InDb();
InDb.find(function(err, clientsend) {
if (err)
res.send(err);
res.json(clientsend);
router.route('/clietsends/:clietsend_id')
InDb.findById(req.params.clietsend_id, function(err, clientsend) {
if (err)
res.send(err);
.put(function(req, res) {
if (err)
res.send(err);
// save the update
if (err)
res.send(err);
res.json(req.body);
//res.json({ message: 'client updated!' });
.delete(function(req, res) {
InDb.remove({
_id: req.params.clietside_id
}, function(err, clientsend) {
if (err)
res.send(err);
//var m = req.body;
delete req.params.clietsend_id;
console.log(req.params.clietsend_id);
res.json({
message: 'Successfully deleted'
// test route to make sure everything is working (accessed at GET http://localhost:8080/api)
router.get('/', function(req, res) {
res.json({
message: 'add /clietsends to view all'
// more routes for our API will happen here
// REGISTER OUR ROUTES -------------------------------
// all of our routes will be prefixed with /api
mailsystem.use('/testapi', router);
// START THE SERVER
mailsystem.listen(port);
console.log('open port' + port);
//function mandrill
function Call_mandrill(email, sub, mess) {
var mandrill = require('mandrill-api/mandrill.js');
function log(obj) {
//$('#response').text(JSON.stringify(obj));
console.log(JSON.stringify(obj));
var m = new mandrill.Mandrill('9VUmdqbiZFiLCev4C_8Q6A');
// LOOK HERE TO CHANGE FROM EMAIL ID
var params = {
"message": {
"from_email": "[email protected]",
"to": [{
"email": email
"subject": sub,
"text": mess,
"autotext": true,
"track_opens": true,
"track_links": true
function sendTheMail() {
m.messages.send(params, function(res) {
log(res);
}, function(err) {
log(err);
function run() {
sendTheMail();
return false;
run();
and clietsend.js in mailsystem/client/
// mailsystem/client/clientside.js
var mongoose = require('mongoose');
var Schema = mongoose.Schema;
var SendSchema = new Schema({
emailId String,
subject String,
message String
module.exports = mongoose.model('Sent', SendSchema);
Everything works fine except I have 2 issues that I couldn't figure out:
1) the body/input is of the form xxx-urlencoded i want it to be in raw so went through this post and did changes to my code as you can see them in comments but they don't seem to work. What am I doing wrong? Can someone show an example?
2) The .delete
function is returning the json object but not deleting it. Don't know why PUT, PUSH, GET seems to work fine though.
after jakerela suggestions made changes accordingly but the issue is on res.json(reqbody) a string is returned where i wanted a json object, and also somethig like "[object object]" is returned along
