67
I have created a new clean asp.net 5 project (rc1-final). Using Identity Authentication I just have the ApplicationDbContext.cs with the following code:
public class ApplicationDbContext : IdentityDbContext<ApplicationUser>
    protected override void OnModelCreating(ModelBuilder builder)
        // On event model creating
        base.OnModelCreating(builder);
Please note ApplicationDbContext use IdentityDbContext and not DbContext.
There is any IdentityConfig.cs. Where i need to put the classic protected override void Seed to create role and user if it does not exist?
Hamid Mosalla
  • 3,279
  • 28
  • 51
Sauron
  • 2,156
12 Answers12
88
My way of doing this is to create a class in models namespace.
public class SampleData
    public static void Initialize(IServiceProvider serviceProvider)
        var context = serviceProvider.GetService<ApplicationDbContext>();
        string[] roles = new string[] { "Owner", "Administrator", "Manager", "Editor", "Buyer", "Business", "Seller", "Subscriber" };
        foreach (string role in roles)
            var roleStore = new RoleStore<IdentityRole>(context);
            if (!context.Roles.Any(r => r.Name == role))
                roleStore.CreateAsync(new IdentityRole(role));
        var user = new ApplicationUser
            FirstName = "XXXX",
            LastName = "XXXX",
            Email = "[email protected]",
            NormalizedEmail = "[email protected]",
            UserName = "Owner",
            NormalizedUserName = "OWNER",
            PhoneNumber = "+111111111111",
            EmailConfirmed = true,
            PhoneNumberConfirmed = true,
            SecurityStamp = Guid.NewGuid().ToString("D")
        if (!context.Users.Any(u => u.UserName == user.UserName))
            var password = new PasswordHasher<ApplicationUser>();
            var hashed = password.HashPassword(user,"secret");
            user.PasswordHash = hashed;
            var userStore = new UserStore<ApplicationUser>(context);
            var result = userStore.CreateAsync(user);
        AssignRoles(serviceProvider, user.Email, roles);
        context.SaveChangesAsync();
    public static async Task<IdentityResult> AssignRoles(IServiceProvider services, string email, string[] roles)
        UserManager<ApplicationUser> _userManager = services.GetService<UserManager<ApplicationUser>>();
        ApplicationUser user = await _userManager.FindByEmailAsync(email);
        var result = await _userManager.AddToRolesAsync(user, roles);
        return result;
To run this code on startup. In Startup.cs at end of configure method just after route configuration add following code as Stafford Williams said before.
SampleData.Initialize(app.ApplicationServices);
Muhammad Abdullah
  • 1,042
  • Yes! That's the way. Awesome code for helping people on seed data. Thanks – Sauron Dec 19 '15 at 17:36
    I was looking for a way to have a user with a fixed Id. The UserManager assigns a new Id when you hand over some ApplicationUser instance for creation. Your approach allows me to set the Id to some fixed value - so thanks for your effort :) – intertag Dec 13 '16 at 14:14
  • System.InvalidOperationException: 'ExecuteReader requires the command to have a transaction when the connection assigned to the command is in a pending local transaction. The Transaction property of the command has not been initialized.' – tnktnk May 17 '17 at 19:19
    There are few async issues in this code (i.e. userStore.CreateAsync is not guaranteed to finish before .AddToRolesAsync is called) but the concept is top – Michal Ja Mar 10 '18 at 17:20
  • You, sir, are a hero. – Chaim Eliyah Nov 26 '18 at 05:28
    Code is missing the async keyword on AssignRoles and context.SaveChangesAsync, and Initialize must return async Task. roleStore.CreateAsync also needs await. – Etienne Charland Mar 27 '19 at 04:03
    This gave me some error about using a scoped service for ApplicationDbContext or something... – Ortund Apr 22 '19 at 11:23
    Getting error saying The non-generic method 'IServiceProvider.GetService(Type)' cannot be used with type arguments – Hamza Khanzada Sep 09 '19 at 14:50
    @HamzaKhanzada the GetService methods are two, Use `public static T GetService` from Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions – Abdul-Razak Adam Oct 04 '20 at 21:38
  • error with using a scoped service for ApplicationDbContext or something – hosam hemaily Dec 03 '21 at 09:26
47
You can seed Users and Roles in OnModelCreating() method inside IdentityDbContext.cs file as shown below. Notice that the keys have to be predefined to avoid seeding new users and roles everytime this method is executed.
protected override void OnModelCreating(ModelBuilder modelBuilder)
        base.OnModelCreating(modelBuilder);
        //Seeding a  'Administrator' role to AspNetRoles table
        modelBuilder.Entity<IdentityRole>().HasData(new IdentityRole {Id = "2c5e174e-3b0e-446f-86af-483d56fd7210", Name = "Administrator", NormalizedName = "ADMINISTRATOR".ToUpper() });
        //a hasher to hash the password before seeding the user to the db
        var hasher = new PasswordHasher<IdentityUser>();
        //Seeding the User to AspNetUsers table
        modelBuilder.Entity<IdentityUser>().HasData(
            new IdentityUser
                Id = "8e445865-a24d-4543-a6c6-9443d048cdb9", // primary key
                UserName = "myuser",
                NormalizedUserName = "MYUSER",
                PasswordHash = hasher.HashPassword(null, "Pa$$w0rd")
        //Seeding the relation between our user and role to AspNetUserRoles table
        modelBuilder.Entity<IdentityUserRole<string>>().HasData(
            new IdentityUserRole<string>
                RoleId = "2c5e174e-3b0e-446f-86af-483d56fd7210",
                UserId = "8e445865-a24d-4543-a6c6-9443d048cdb9"
Hamza Dahmoun
  • 1,204
  • This is a working solution in .NET Core 3.1 (if you're okay with hardcoding some test data). I am using this approach myself. – barnacle.m Oct 02 '20 at 09:21
    This worked for me while the accepted one on top did not. Thanks – Venugopal M Oct 05 '20 at 09:50
    This is the correct answer for .NET 5.0 as well. – display-name Mar 09 '21 at 16:33
    This is not recommended by Micro$oft – Jonathan Daniel Apr 25 '21 at 07:44
    @JonathanDaniel can you post a link to verify what you stated? i was looking into this and found this, which im assuming is showing the best approach if you meet certain factors. https://learn.microsoft.com/en-us/ef/core/modeling/data-seeding – Heriberto Lugo Aug 05 '21 at 02:48
  • @HeribertoLugo in the page you linked is written "Data that requires calls to external API, such as ASP.NET Core Identity roles and users creation'' – Jonathan Daniel Nov 10 '21 at 19:05
  • @JonathanDaniel and? I was hoping you could provide documentation which states this is not recommended, because I could not find such and only found documentation which states it is valid. – Heriberto Lugo Nov 10 '21 at 23:20
  • @JonathanDaniel you provided an authoritive statement without an authority to back it up. Personally I ended up using a different approach for ease of use, flexibility and better organization. But I still don't see any documentation stating this is bad practice or not recommended by Microsoft. Which is what I wanted to read. – Heriberto Lugo Nov 10 '21 at 23:23
    @HeribertoLugo I am quoting literally what microsoft wrote: "If your scenario includes any of the following it is recommended to use custom initialization logic described in the last section: ... Data that requires calls to external API, such as ASP.NET Core Identity roles and users creation" – Jonathan Daniel Nov 11 '21 at 06:39
  • you're right.. not sure how i overlooked that last bullet point about 5 times of reading it. thanks for pointing it out twice. – Heriberto Lugo Nov 11 '21 at 06:52
    I think the problem with this answer is that it updates Concurrency Stamp whenever new migration is added. It's not recommended but it does the trick. – Lukasz Pomianowski Jan 03 '22 at 13:39
    @LukaszPomianowski is right: i was using this and i'm switching to **seed** version because ASPNet.core detects again and again changes in the database context and complains about pending changes... furthermore, each time you use the migrate command without real changes, it detects changes on the Concurrency stamp and generates a new migration. – TwiXter Mar 15 '22 at 16:16
34
As of the time of this writing, there is no plug in place for seeding the database, but you can create a class and add it to your container to do the same thing on app start, here is how I've done it, first create a class:
public class YourDbContextSeedData
    private YourDbContext _context;
    public YourDbContextSeedData(YourDbContext context)
        _context = context;
    public async void SeedAdminUser()
            UserName = "[email protected]",
            NormalizedUserName = "[email protected]",
            LockoutEnabled = false,
            SecurityStamp = Guid.NewGuid().ToString()
        var roleStore = new RoleStore<IdentityRole>(_context);
        if (!_context.Roles.Any(r => r.Name == "admin"))
            await roleStore.CreateAsync(new IdentityRole { Name = "admin", NormalizedName = "admin" });
        if (!_context.Users.Any(u => u.UserName == user.UserName))
            var hashed = password.HashPassword(user, "password");
            var userStore = new UserStore<ApplicationUser>(_context);
            await userStore.CreateAsync(user);
            await userStore.AddToRoleAsync(user, "admin");
        await _context.SaveChangesAsync();
Register the type in ConfigureServices method of your Startup.cs class:
services.AddTransient<YourDbContextSeedData>();
Next pass the YourDbContextSeedData class to the Configure method of your Startup.cs class and use it:
public void Configure(IApplicationBuilder app, IHostingEnvironment env, ILoggerFactory loggerFactory, YourDbContextSeedData seeder)
  seeder.SeedAdminUser();
Hamid Mosalla
  • 3,279
  • 28
  • 51
    After many wasted hours trying to seed an admin level account in my core 2 app a slightly modified version of your post finally did it for me while all other approaches failed when i called the AddToRoleAsync method. Thank you so much! – Nathan Oct 21 '17 at 21:31
  • This was helpful, thanks @Hamid. I would suggest to others that you actually call the initializer from `Program.Main()` - see [this answer](https://stackoverflow.com/a/52709902/11870335) for an explanation. My app would not load consistently until I moved the initialization out of startup. And per [this post](https://stackoverflow.com/a/40184150/11870335), you may want to consider using `UserManager` and `RoleManager` for validation. – ChiefMcFrank Apr 18 '20 at 23:50
  • Note that the call: `await userStore.AddToRoleAsync(user, "admin");` the "admin" is the normalized value of the Role so if yours differ be sure to make sure it reflects the value specified in the normalized role. – bnns Jun 14 '20 at 11:12
    Got this to work in EF6. My gotcha was the normalized username and email had to be UPPERCASE! – Shane Apr 01 '21 at 06:06
If you have async issues, try the following code:
    protected override void Seed(ApplicationDbContext context)
        //  This method will be called after migrating to the latest version.
        string[] roles = new string[] { "Admin", "User" };
                context.Roles.Add(new IdentityRole(role));
        //create user UserName:Owner Role:Admin
        if (!context.Users.Any(u => u.UserName == "Owner"))
            var userManager = new UserManager<ApplicationUser>(new UserStore<ApplicationUser>(context));
                FirstName = "XXXX",
                LastName = "XXXX",
                UserName = "Owner",
                SecurityStamp = Guid.NewGuid().ToString("D"),
                PasswordHash = userManager.PasswordHasher.HashPassword("secret"),
                LockoutEnabled = true,
            userManager.Create(user);
            userManager.AddToRole(user.Id, "Admin");
        context.SaveChanges();
Tracy Zhou
  • 714
In aspnetcore there is the concept of IHostedService. This makes it possible to run async background Task.
The solution of @hamid-mosalla could be made async and called from an IHostedService implementation.
Seed class implementation could be something like
public class IdentityDataSeeder
    private readonly UserManager<ApplicationUser> _userManager;
    private readonly RoleManager<IdentityRole> _roleManager;
    public IdentityDataSeeder(
        UserManager<ApplicationUser> userManager,
        RoleManager<IdentityRole> roleManager)
        _userManager = userManager;
        _roleManager = roleManager;
    public async Task SeedAsync()
        var superAdminRole = new IdentityRole
            Id = "cac43a6e-f7bb-4448-baaf-1add431ccbbf",
            Name = "SuperAdmin",
            NormalizedName = "SUPERADMIN"
        await CreateRoleAsync(superAdminRole);
        var superAdminUserPassword = "P@ssword1";
        var superAdminUser = new ApplicationUser
            Id = "b8633e2d-a33b-45e6-8329-1958b3252bbd",
        await CreateUserAsync(superAdminUser, superAdminUserPassword);
        var superAdminInRole = await _userManager.IsInRoleAsync(superAdminUser, superAdminRole.Name);
        if (!superAdminInRole)
            await _userManager.AddToRoleAsync(superAdminUser, superAdminRole.Name);
    private async Task CreateRoleAsync(IdentityRole role)
        var exits = await _roleManager.RoleExistsAsync(role.Name);
        if (!exits)
            await _roleManager.CreateAsync(role);
    private async Task CreateUserAsync(ApplicationUser user, string password)
        var exists = await _userManager.FindByEmailAsync(user.Email);
        if (exists == null)
            await _userManager.CreateAsync(user, password);
This can be called from an IHostedService:
public class SetupIdentityDataSeeder : IHostedService
    private readonly IServiceProvider _serviceProvider;
    public SetupIdentityDataSeeder(IServiceProvider serviceProvider)
        _serviceProvider = serviceProvider;
    public async Task StartAsync(CancellationToken cancellationToken)
        using (var scope = _serviceProvider.CreateScope())
            var seeder = scope.ServiceProvider.GetRequiredService<IdentityDataSeeder>();
            await seeder.SeedAsync();
    public Task StopAsync(CancellationToken cancellationToken) => Task.CompletedTask;
Startup would look like:
public void ConfigureServices(IServiceCollection services)
    services.AddHostedService<SetupIdentityDataSeeder>();
Orhan
  • 420
    From my understanding, an IHostedService continually runs in the background until the application process is stopped. If that is the case, then it is not the appropriate place to do a one-time task like seeding the database. – pnavk Nov 10 '20 at 06:14
  • @pnavk the documentation states: `The hosted service is activated once at app startup and gracefully shut down at app shutdown.` See [MS docs](https://learn.microsoft.com/en-us/aspnet/core/fundamentals/host/hosted-services?view=aspnetcore-3.1&tabs=visual-studio). – Orhan Nov 10 '20 at 08:19
    Yes, that is exactly my point. A hosted service is used for something that needs to run repeatedly the entire time your application is running. If you want to seed the database with something (a task that only needs to happen once), you can do it just once during app start (with async support) up as shown here: https://stackoverflow.com/a/52709902/2754727 – pnavk Nov 10 '20 at 09:27
    @pnavk It is not true that it needs to run repeatedly the entire time. `IHostedService` is used for background tasks and scheduled jobs. Here it is used to run the code as a background task. To run it repeatedly you need to make use of the `Timer`. Since that is not done here this will run once at application start. I just want to offload a task to the background and I am using a build in mechanism for that. – Orhan Nov 11 '20 at 08:05
My way:
  1. Create Class in models folder
    public static class ModelBuilderExtensions
         public static void Seed(this ModelBuilder builder)
        // Seed Roles
        List<IdentityRole> roles = new List<IdentityRole>()
            new IdentityRole { Name = "Admin", NormalizedName = "ADMIN" },
            new IdentityRole { Name = "User", NormalizedName = "USER" }
        builder.Entity<IdentityRole>().HasData(roles);
        // Seed Users
        var passwordHasher = new PasswordHasher<ApplicationUser>();
        List<ApplicationUser> users = new List<ApplicationUser>()
             // imporant: don't forget NormalizedUserName, NormalizedEmail
                     new ApplicationUser {
        builder.Entity<ApplicationUser>().HasData(users);
        // Seed UserRoles
        List<IdentityUserRole<string>> userRoles = new List<IdentityUserRole<string>>();
          // Add Password For All Users
            users[0].PasswordHash = passwordHasher.HashPassword(users[0], "User.123");
            users[1].PasswordHash = passwordHasher.HashPassword(users[1], "User.155");
             userRoles.Add(new IdentityUserRole<string> { UserId = users[0].Id, RoleId =
             roles.First(q => q.Name == "User").Id });
             userRoles.Add(new IdentityUserRole<string> { UserId = users[1].Id, RoleId =
             roles.First(q => q.Name == "Admin").Id });
        builder.Entity<IdentityUserRole<string>>().HasData(userRoles);
  2. in DBContext
    public class AppDbContext : IdentityDbContext<ApplicationUser>
    public AppDbContext(DbContextOptions<AppDbContext> options)
        : base(options)
        // Use seed method here
        builder.Seed();
splinter.cell
  • 113
  • This solution will re-create roles as the ID is not provided. Then it will update Concurrency stamp unless that will be provided too. Almost the same as @hamza's answer – Lukasz Pomianowski Jan 03 '22 at 13:42
  • Not exactly. `HasData` works with your schema's data. A migration must be created for it to make any inserts, updates, or deletes. See https://stackoverflow.com/questions/71744108/ef-core-hasdata-not-being-called-inside-onmodelcreating for clarity. – Adam Rodriguez Aug 15 '23 at 23:01
This is not yet implemented. As a work around, just write your own class that will check the database for the existence of your entities, add them if they don't exist, and call this class from your Startup.cs.
Stafford Williams
  • 9,696
  • 50
  • 101
    As per Microsoft, `The seeding code should not be part of the normal app execution as this can cause concurrency issues when multiple instances are running and would also require the app having permission to modify the database schema.` https://learn.microsoft.com/en-us/ef/core/modeling/data-seeding#custom-initialization-logic – Hamza Khanzada Nov 22 '19 at 11:48
  • @HamzaKhanzada I first check if env is development and then seed, and then I create a seperate program that will seed it for production that should be ran manually once. – Jonathan Daniel Apr 25 '21 at 07:46
Add the following class in Models namespace. It works for adding multiple users and roles, and will also add roles to existing users (e.g. facbook logins). Call it like this app.SeedUsersAndRoles(); from startup.cs
    using System;
using System.Collections.Generic;
using System.Linq;
using System.Threading.Tasks;
using Microsoft.AspNet.Builder;
using Microsoft.Extensions.DependencyInjection;
using Microsoft.AspNet.Identity.EntityFramework;
using Microsoft.AspNet.Identity;
namespace MyApplication.Models
    public static class DataSeeder
        public static async void SeedUsersAndRoles(this IApplicationBuilder app)
            var context = app.ApplicationServices.GetService<ApplicationDbContext>();
            UserWithRoles[] usersWithRoles = {
                new UserWithRoles("Admin", new string[] { "Administrator" , "Distributor" },"somepassword"),//user and optional roles and password you want to seed
                new UserWithRoles("PlainUser"),
                new UserWithRoles("Jojo",new string[]{"Distributor" }) //seed roles to existing users (e.g. facebook login).
            foreach (var userWithRoles in usersWithRoles)
                foreach (string role in userWithRoles.Roles)
                        await roleStore.CreateAsync(new IdentityRole(role));
                var ExistingUser = context.Users.FirstOrDefault(p => p.NormalizedUserName == userWithRoles.User.NormalizedUserName);
                if (ExistingUser == null) //the following syntax: !context.Users.FirstOrDefault(p => p.NormalizedUserName == userWithRoles.User.NormalizedUserName))
                                            //provokes execption:(ExecuteReader requires an open and available Connection.)
                    await new UserStore<ApplicationUser>(context).CreateAsync(userWithRoles.User);
                await app.AssignRoles(userWithRoles); //assign also to existing users.
        public static async Task<IdentityResult> AssignRoles(this IApplicationBuilder app, UserWithRoles uWR)
            UserManager<ApplicationUser> _userManager = app.ApplicationServices.GetService<UserManager<ApplicationUser>>();
            ApplicationUser user = await _userManager.FindByNameAsync(uWR.User.NormalizedUserName);
            var result = await _userManager.AddToRolesAsync(user, uWR.Roles);
            return result;
    public class UserWithRoles
        private ApplicationUser user;
        public ApplicationUser User { get { return user; } }
        public string[] Roles { get; set; }
        public UserWithRoles(string name, string[] roles = null, string password = "secret")
            if (roles != null)
                Roles = roles;
            else
                Roles = new string[] { };
                Email = name + "@gmail.com", NormalizedEmail = name.ToUpper() + "@GMAIL.COM",
                UserName = name, NormalizedUserName = name.ToUpper(),
                PhoneNumber = "+1312341234",
            user.PasswordHash = new PasswordHasher<ApplicationUser>().HashPassword(user, password);
Guy
  • 1,232
So this is solution based on Muhammad Abdullah answer. Included few code improvements, improved readability of code and got it to work with .net core 2.
 public class Seed
        public static async Task Initialize(IServiceProvider serviceProvider, IConfiguration configuration)
            var usrName = configuration.GetSection("Admin").GetSection("UserName").Value;
            var email = configuration.GetSection("Admin").GetSection("Email").Value;
            var pass = configuration.GetSection("Admin").GetSection("Pass").Value;
            var roles = new string[4] { OWNER, ADMIN, SENIOR, USER };
            if(await CreateUser(serviceProvider, email, usrName, pass, roles))
                await AddToRoles(serviceProvider, email, roles);
        private static async Task<bool> CreateUser(IServiceProvider serviceProvider, string email, string usrName, string pass, string[] roles)
            var res = false;
            using (var scope = serviceProvider.CreateScope())
                var context = scope.ServiceProvider.GetService<BaseContext>();
                if (!context.ApplicationUsers.Any(u => u.NormalizedUserName == usrName.ToUpper()))
                    var roleStore = scope.ServiceProvider.GetService<RoleManager<IdentityRole>>();
                            await roleStore.CreateAsync(new IdentityRole(role)).ConfigureAwait(false);
                        UserName = usrName,
                        Email = email,
                        NormalizedEmail = email.ToUpper(),
                        NormalizedUserName = usrName.ToUpper(),
                        PhoneNumber = null,
                    user.PasswordHash = password.HashPassword(user, pass); ;
                    res = (await userStore.CreateAsync(user).ConfigureAwait(false)).Succeeded;
                return res;
        private static async Task AddToRoles(IServiceProvider serviceProvider, string email, string[] roles)
                var userManager = scope.ServiceProvider.GetService<UserManager<ApplicationUser>>();
                var usr = await userManager.FindByEmailAsync(email).ConfigureAwait(false);
                await userManager.AddToRolesAsync(usr, roles).ConfigureAwait(false);
Michal Ja
  • 252
Seems this thread is very old, but it will still work for someone who wants to seed their identity tables data in entityframework core.
You can simple try the below.
               new IdentityUser { Id= "-1", UserName="sagark",PasswordHash="sagark", Email="emailid goes here" }
David Buck
  • 3,752
  • 35
  • 35
    This approach is NOT recommended. How will you login without a properly hashed password? Additionally, without a preset ID you will never be able to add the user to any roles or establish any relationships when seeding. – barnacle.m Oct 02 '20 at 09:14
The following line create the entry in the AspNetRoles table but does not populate the NormalizedName column.
Substitute with the following for this column to be populated:
RoleManager<IdentityRole> roleManager = serviceProvider.GetService<RoleManager<IdentityRole>>();
roleManager.CreateAsync(new IdentityRole(role));
By Using Extension Method.
namespace Course.Repository.Utilities {
    public  static class AddRoleToAdmin {
       public static void ConfigurationUserAndRole(this ModelBuilder modelBuilder)
                new IdentityRole()
                    Name = "Admin",
                    NormalizedName = "Admin".ToUpper()
            // Seeding the User to AspNetUsers table
            modelBuilder.Entity<AppUser>().HasData(
               new AppUser()
                   Id= "8e445865-a24d-4543-a6c6-9443d048cdb9",
                   NormalizedUserName = "[email protected]".ToUpper(),
                   NormalizedEmail = "[email protected]".ToUpper(),
                   PasswordHash = hasher.HashPassword(null, "Admin123"),
                new IdentityUserRole<string>()
                    RoleId= "2c5e174e-3b0e-446f-86af-483d56fd7210", // 2c5e174e-3b0e-446f-86af-483d56fd7210
                    UserId = "8e445865-a24d-4543-a6c6-9443d048cdb9" // 8e445865-a24d-4543-a6c6-9443d048cdb9
OnModelCreating In DbContext
             // Call Extension Method.
            modelBuilder.ConfigurationUserAndRole();
Ragab Mohamad
  • 371
