i am trying to use my keyboard to click on a button using the id.
For some buttons i had to set the ID, which actually works. But as soon as i try to use the keyboard for the buttons where i set the id, it won't work.
I am not getting any errors and since adding the id to the element works, i am kinda confused why i cannot use the new set id later in the code.
//setting id for first button (works)
$( "a:contains('Im Verband freigeben')" ).attr('id', 'freigabe-verband');
//setting id for second button (works aswell)
$( "a:contains('Vorheriger Einsatz')" ).attr('id', 'vorheriger-einsatz');
$( document ).keydown(function(e) {
 if (e.keyCode == 39) {
    //works, id is available, not set by me
     $("#alert_next").click();
} else if (e.keyCode == 38){
    // doesn't work, but id is set
    $("#freigabe-verband").click();
} else if (e.keyCode == 40){
    $("#vorheriger-einsatz").click();
return e.returnValue;
Anyone know why? https://i.stack.imgur.com/nQtRc.png
lost.design
  • 163
  • The DOM doesn't know that you have given that object an `id`, you need to delegate the event. – Sterling Archer Dec 16 '15 at 15:27
  • This works fine for me: https://jsfiddle.net/es8oxgjc/ . But I'm executing the jQuery onload in that fiddle. Can you wrap it in a document.ready and see if it works for you then? – andi Dec 16 '15 at 15:38
  • If you are trying to simulate a anchor click see this link. http://stackoverflow.com/questions/773639/how-can-i-simulate-an-anchor-click-via-jquery#answer-773738 – Sean Wessell Dec 16 '15 at 15:40
  • your code does work for any other handlers that are bound. https://jsfiddle.net/SeanWessell/s2p4wd48/ – Sean Wessell Dec 16 '15 at 15:41
  • Well yeah, that makes sense. Not sure how to delegate it, gotta look it up. – lost.design Dec 16 '15 at 15:46
To click a dom element, use:-
$('#freigabe-verband')[0].click();
or
$('#freigabe-verband').get(0).click();
Example
$("a").attr('id', 'test');
$(document).keydown(function(e) {
 $('#test')[0].click();
<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script>
<a href="http://stackoverflow.com">link</a>
BenG
  • 14,826
  • 45
  • 60
It doesn't make sense. I copy your code and create a plunkr, it works well. http://plnkr.co/edit/Eb5QF6mB97Js41NFbr8J?p=preview
// Code goes here
$(function() {
    // arrow up
    // arrow down
<!DOCTYPE html>
<html>
  <head>
    <script data-require="[email protected]" data-semver="2.1.4" src="https://code.jquery.com/jquery-2.1.4.js"></script>
    <link rel="stylesheet" href="style.css" />
    <script src="script.js"></script>
  </head>
  <body>
    <h1>Hello Plunker!</h1>
    <a href="#" onclick="alert('a');">Im Verband freigeben</a><br>
    <a href="#" onclick="alert('b');">Vorheriger Einsatz</a>
  </body>
</html>
yukuan
  • 521
  • 18
Try this example:
$(document).find("#vorheriger-einsatz").click();
You're adding to the DOM after the fact so unless you search the dom again it won't be found
StudioTime
  • 22,603
  • 38
  • 120
  • 207
