var express = require('express');
var path = require('path');
var favicon = require('serve-favicon');
var logger = require('morgan');
var cookieParser = require('cookie-parser');
var bodyParser = require('body-parser');
var expressValidator = require('express-validator');
var routes = require('./routes/index');
var users = require('./routes/users');
var auth = require('./routes/auth');
var app = express();
// view engine setup
app.set('views', path.join(__dirname, 'views'));
app.set('view engine', 'jade');
// uncomment after placing your favicon in /public
//app.use(favicon(path.join(__dirname, 'public', 'favicon.ico')));
app.use(logger('dev'));
app.use(bodyParser.json());
app.use(bodyParser.urlencoded({ extended: false }));
//validator
app.use(expressValidator({
  errorFormatter: function(param, msg, value) {
    var namespace = param.split('.')
        , root    = namespace.shift()
        , formParam = root;
    while(namespace.length) {
      formParam += '[' + namespace.shift() + ']';
    return {
      param : formParam,
      msg   : msg,
      value : value
app.use(cookieParser());
app.use(express.static(path.join(__dirname, 'public')));
app.use('/', routes);
app.use('/users', users);
app.use('/auth', auth);
// catch 404 and forward to error handler
app.use(function(req, res, next) {
  var err = new Error('Not Found');
  err.status = 404;
  next(err);
// error handlers
// development error handler
// will print stacktrace
if (app.get('env') === 'development') {
  app.use(function(err, req, res, next) {
    res.status(err.status || 500);
    res.render('error', {
      message: err.message,
      error: err
// production error handler
// no stacktraces leaked to user
    error: {}
module.exports = app;
this section is app.js
var router = express.Router();
router.post('/register', function(req,res,next) {
    // Get Form Values
    var email = req.body.email;
    var username = req.body.username;
    var password = req.body.password;
    var password2 = req.body.password2;
    // Form Validation
    req.checkBody('email','Email field is required').notEmpty();
    req.checkBody('email','Email not valid').isEmail();
    req.checkBody('username','Username field is required').notEmpty();
    req.checkBody('password','Password field is required').notEmpty();
    req.checkBody('password2','Passwords do not match').equals(req.body.password);
    var errors = req.validationErrors();
    if(errors){
        console.log(req.body);
        console.log(req.param);
        console.log(errors);
    } else{
        res.send('email : ' + email +'username : ' + username + ' password : ' + password);
module.exports = router;
this section is auth.js
<!doctype html>
<html>
<head>
    <meta charset="UTF-8">
    <meta name="viewport" content=""width="device-width,initial-scale=1.0"/>
    <meta name="description" content="" />
    <meta name="copyright" content="" />
    <title>project</title>
    <link rel="stylesheet" href="jquery/jquery.mobile-1.4.5.min.css"/>
    <script src="jquery/jquery.min.js"></script>
    <script src="jquery/jquery.mobile-1.4.5.min.js"></script>
</head>
<body>
    <div data-role="page" id = "loginpage">
        <div data-role="header">
        </div>
        <div data-role="content">
        <h1>My Project</h1>
        <form method="post" action="" enctype="application/x-www-form-urlencoded">
            <input type="text" class="username" placeholder="username" />
            <input type="password" class="password" onfocus="this.value = '';" placeholder="password" />
            <input type="submit" class="button" value="LOGIN" />
        </form>
        <a href="#registerpage">Not a member? Signup now</a>
        </div>
    </div>
    <div data-role="page" id="registerpage">
        </div>
        <form  method="post" action="http://127.0.0.1:3000/auth/register"  enctype="application/x-www-form-urlencoded">
            <input type="text" class="username" placeholder="Username"/>
            <input type="password" class="password" onfocus="this.value = '';" placeholder="Password" />
            <input type="text" class="email" placeholder="[email protected]"/>
            <input type="password" class="password2" onfocus="this.value = '';" placeholder="Check Password" />
            <input type="submit" class="button" value="Register" />
        </form>
        </div>
    </div>
</body>
</html>
this part is client part
I'm developing client part and server part separately
I don't know why body-parser does not work
request body is always undefined.
express version : 4.13.3 body-parser version : 1.14.1
Aram_Yook
