I'd like to change a partial view to be rendered on click. I have spent a lot of time searching the solution on google.
The part is rendered while loading a main page.
<div id="tableContent">
    @{Html.RenderPartial("GetTableView", Model);}
</div>
I'd like to have this paritial loaded on click, something like this:
    <input type="button" class="btn btn-default"
     onclick="Render Partial "GetTableView" in tableContent (replace the content)" />
</div>
My Model
public class ImportModel
    public class ImportFileDetails
        [Display(Name = "File Name")]
        public string Filename { get; set; }
        [Display(Name = "Total Columns")]
        public int TotalColumns { get; set; }
        [Display(Name = "Total Rows")]
        public int TotalRows { get; set; }
        [Display(Name = "Import Rows")]
        public int ImportRows { get; set; }
        public List<string> Header { get; set; }
        public ICollection<RepCodesFile> RepCodesFile { get; set; }
public class RepCodesFile
    public string RepCode { get; set; }
    public string Description { get; set; }
My Controller
    public ActionResult ImportFile(string ImportFile)
        ImportModel.ImportFileDetails File = new Models.ImportModel.ImportFileDetails();
        // Model is passed to View corectly
        return View(File);
My Main View
@model Models.ImportModel.ImportFileDetails
    ViewBag.Title = "Import";
<h2>@ViewBag.Title</h2>
<hr />
@if (Model.Filename != null || Model.ImportRows == 0)
    </div>
else
    <h4 class="text-warning">No data for import</h4>
My Partial
    <table id="filetable" class="table table-bordered pagination" cellspacing="0">
        <thead>
            <tr>
            @foreach (string item in Model.Header)
                <th>@item</th>
            </tr>
        </thead>
        <tbody>
            foreach (AutogemCMS.Models.RepCodesFile item in Model.RepCodesFile)
                <tr>
                    <td>@item.RepCode</td>
                    <td>@item.Description</td>
                </tr>
        </tbody>
    </table>
Please help.
Thanks
Loading GIF solution: It's not what i wanted but good enough for me.
Controller:
    if (Request.IsAjaxRequest())
        return PartialView("GetTableView", File);
    else
        return View(File);
Main View:
    <img src="~/Content/images/ajax-loader.gif" class="center-block img-responsive" />
</div>
$(function () {
    $.ajax({
        url: '/Import/[email protected]',
        dataType: 'html',
        success: function (data) {
            $('#tableContent').html(data);
Maludasek
  • 117
    Too much irrelevant code - please read this: http://stackoverflow.com/help/mcve – freedomn-m Aug 06 '15 at 09:12
  • freedomn-m - is it possible you could help me now? – Maludasek Aug 06 '15 at 09:57
  • You should have a look at @Ajax.ActionLink(), or if you don't mind doing a whole page refresh/flicker, @Html.ActionLink –  Aug 06 '15 at 09:59
  • Is this something like you're looking for? `'$(".btn-default").click(function() { $("#tableContent").load('@Url.Action("GetTableView", Model))'); });'` – freedomn-m Aug 06 '15 at 10:07
  • I haven't implemented the use of the helpers mentioned by @akemp but I would try doing [this](http://stackoverflow.com/questions/7430976/rendering-partial-views-using-ajax). – MiddleKay Aug 06 '15 at 10:11
  • The problem is that Ajax doesnt want to pass collections/lists in model. public List Header { get; set; }] and public ICollection RepCodesFile { get; set; } – Maludasek Aug 06 '15 at 10:51
  • Problem partially solved with @MiddleKay help by adding Loading GIF. Later time i will work on passing less complicated model to partial view. Thanks All – Maludasek Aug 06 '15 at 12:28
by click event in javascript
$("#tableContent").load('@Url.Action("PartialViewResult", "Controller_Name")');
N.B.: PartialViewResult must return PartialView(model) and .cshtml page a partial page.
Peter Tretyakov
  • 3,380
  • 38
  • 54
AbdusSalam
  • 420
Create, for example, an ActionLink:
@Ajax.ActionLink("Any Text Here", "ImportFile", "ControllerName", null, new AjaxOptions { InsertionMode = InsertionMode.Replace, HttpMethod = "get", UpdateTargetId = "tableContent" })
And then change you Action, to return a partial View, as follow:
public PartialViewResult ImportFile(string ImportFile)
    return PartialView("PartialView", model);
Place content div (id=tableContent). The content will be replaced with partial view:
Put inside:
a. hidden loading gif animation - id=loading
b. action button - id=showContent
Execute an action button on click to remove button, unhide gif animation and run ajax which will get the partial view.
    <input type="button" class="btn btn-primary" id="showContent" value="Show Content" />
    <img id="loading" src="~/Content/images/ajax-loader.gif" class="center-block img-responsive hidden" />
</div>
<script>
    $('#showContent').click(function () {
        $('#showContent').remove();
        $('#loading').removeClass("hidden");
        $.ajax({
            dataType: 'html',
            async: true,
</script>
Maludasek
  • 117
