What's the purpose of boost::to_string (found in boost/exception/to_string.hpp) and how does it differ from boost::lexical_cast<std::string> and std::to_string?
- 224,032
- 165
- 485
- 680
10If I recall the history correctly, `boost::to_string` preceded `std::to_string`, as is typically the case. Boost tends to be the playground for stuff before it gets accepted into the standard library. `std::to_string` is new as of C++11. – Cory Kramer Apr 01 '15 at 19:21
@Cyber: I'd suggest you write this as a (partial) answer. – MikeMB Apr 01 '15 at 19:40
1@CoryKramer, `boost::to_string` might be older, but it's not the same as `std::to_string` and `std::to_string` was not based on it (they just happen to use the same name). – Jonathan Wakely Jan 17 '17 at 13:58
std::to_string, available since C++11, works on fundamental numeric types specifically. It also has a std::to_wstring variant.
It is designed to produce the same results that sprintf would.
You may choose this form to avoid dependencies on external libraries/headers.
The throw-on-failure function boost::lexical_cast<std::string> and its non-throwing cousin boost::conversion::try_lexical_convert work on any type that can be inserted into a std::ostream, including types from other libraries or your own code.
Optimized specializations exist for common types, with the generic form resembling:
template< typename OutType, typename InType >
OutType lexical_cast( const InType & input )
// Insert parameter to an iostream
std::stringstream temp_stream;
temp_stream << input;
// Extract output type from the same iostream
OutType output;
temp_stream >> output;
return output;
You may choose this form to leverage greater flexibility of input types in generic functions, or to produce a std::string from a type that you know isn't a fundamental numeric type.
boost::to_string isn't directly documented, and seems to be for internal use primarily. Its functionality behaves like lexical_cast<std::string>, not std::to_string.
- 59,987
- 13
- 123
- 180
There are more differences: boost::lexical_cast works a bit different when converting double to string. Please consider the following code:
#include <limits>
#include <iostream>
#include "boost/lexical_cast.hpp"
int main()
double maxDouble = std::numeric_limits<double>::max();
std::string str(std::to_string(maxDouble));
std::cout << "std::to_string(" << maxDouble << ") == " << str << std::endl;
std::cout << "boost::lexical_cast<std::string>(" << maxDouble << ") == "
<< boost::lexical_cast<std::string>(maxDouble) << std::endl;
return 0;
Results
$ ./to_string
std::to_string(1.79769e+308) == 179769313486231570814527423731704356798070600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000
boost::lexical_cast<std::string>(1.79769e+308) == 1.7976931348623157e+308
As you can see, the boost version uses exponential notation (1.7976931348623157e+308) whereas std::to_string prints every digit, and six decimal places. One may be more useful than another for your purposes. I personally find the boost version more readable.
- 1,473
- 2
- 17
- 31
- 149
- 1
- 3
3Please do a bit more than just pasting some code. Describe *what* your code does and *how* it does it. – Paul Kertscher Jan 17 '17 at 13:38
1It is simple the output of to_string() and lexical_cast() for the same double value ;-)) – Claus Klein Jan 17 '17 at 15:28
2Those results certainly differ - and that's worth noting. But it's not obvious to me which result is more "right". – Drew Dormann Jan 17 '17 at 21:10
