I am trying to run an OpenGL example from here: https://github.com/robclark/kmscube on Hummingboard running Debian Wheezy.
I have all necessary libraries except libgbm. Installing libgbm-dev that was on aptitude left me with some errors such as "undefined reference to `gbm_surface_release_buffer' "
Looking at libgbm sources here: https://github.com/robclark/libgbm I noticed there functions were added to the latest version, so I understand that I need to rebuild this library from source.
This library uses autoconfig tools,
So I ran the following
libtoolize
aclocal
autoconf
autoheader
automake --force-missing --add-missing
libtoolize returns the following:
libtoolize: You should add the contents of the following files to `aclocal.m4':
libtoolize: `/usr/share/aclocal/libtool.m4'
libtoolize: `/usr/share/aclocal/ltoptions.m4'
libtoolize: `/usr/share/aclocal/ltversion.m4'
libtoolize: `/usr/share/aclocal/ltsugar.m4'
libtoolize: `/usr/share/aclocal/lt~obsolete.m4'
libtoolize: Remember to add `LT_INIT' to configure.ac.
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.ac and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
Automake returns the following
Makefile.am:1: Libtool library used but `LIBTOOL' is undefined
Makefile.am:1: The usual way to define `LIBTOOL' is to add `LT_INIT'
Makefile.am:1: to `configure.ac' and run `aclocal' and `autoconf' again.
Makefile.am:1: If `LT_INIT' is in `configure.ac', make sure
Makefile.am:1: its definition is in aclocal's search path.
The output of libtoollize is not very descriptive, what do I need to do in order to make it the contents of those files?
In addition I also had to make changes to configure.ac file with AC_INIT(gbm, 2.69, [email protected]) AM_INIT_AUTOMAKE(gbm, 2.69)
And add files NEWS, AUTHORS, and ChangeLog
This seems like an incorrect process, isn't there an automated way to do this?
Can someone guide me through building this library?
