98
In order to stage python project within our corporation I need to make an installable distribution.
This should include:
  • An egg or whl for my project
  • An egg or whl for every dependency of the project
  • (optionally) produce a requirements.txt file listing all the installable components for this release
Is there an easy plug in, (e.g. an alternative to bdist_wheel) that will not only compile one wheel but also that project's components?
Obviously I can script this, but I was hoping that there might be a short-cut that builds the package + dependencies in fewer steps.
This needs to work on Python 2.7 on Windows + Linux.
Martijn Pieters
  • 1,048,767
  • 296
  • 4,058
  • 3,343
Salim Fadhley
  • 6,975
  • 46
  • 83
You will need to create a setup.py file for your package. Make sure you have the latest setuptools and pip installed. Then run the following:
python setup.py bdist_wheel
This will create a wheel file for your package. This assumes you don't have C/C++ headers, DLLs, etc. If you do, then you'll probably have a lot more work to do.
To get dependencies, you will want to create a requirements.txt file and run the following:
pip wheel .
If your package isn't on PyPI, then you'll have to manually copy your package's wheel file into the wheel folder that this command creates. For more information see the following excellent article:
Mike Driscoll
  • 32,629
  • 45
  • 88
92
With the latest pip and wheel, you can simply run
pip wheel .
within your project folder, even if your application isn't on PyPi. All wheels will be stored in the current directory (.).
To change the output directory (to for example, ./wheels), you may use the -w / --wheel-dir option:
pip wheel . -w wheels
All the options available are listed at the pip documentation.
Niko Föhr
  • 28,336
  • 93
  • 96
jtpereyda
  • 6,987
  • 51
  • 80
    It search my local packages on pypi so it fails. Instead, I run `python setup.py bdist_wheel` first, then run `pip wheel -r requirements.txt` for pypi packages. – guneysus Oct 04 '16 at 11:44
    I just tried it and it writes the wheel files to your working directory by default (not ./wheelhouse). Also, any idea how to specify the name of the output file? I'm not seeing anything in the docs. – weberc2 Jul 16 '19 at 19:58
    This gives me a million wheels. How do I get one big wheel file? – rjurney Apr 28 '21 at 17:37
    @rjurney Wheels are not meant to be one single installer for all dependencies. You can add `--no-deps` to only build your project. Actually `pip wheel --no-deps -w dist .` is quite similar to `python setup.py bdist_wheel`. – Corbie Jul 30 '21 at 08:40
    @Corbie yes, I wanted a `wagon` - https://github.com/cloudify-cosmo/wagon - a zip file of all the wheels. Databricks and other systems use this format to avoid having a million wheels lying around for uploading or integration. – rjurney Jul 31 '21 at 02:08
With poetry you can define your dependencies and metadata about your project in a file in the root of your project, called pyproject.toml:
[tool.poetry]
name = "my-project"
version = "0.1.0"
description = "some longer description"
authors = ["Some Author <[email protected]>"]
[tool.poetry.dependencies]
python = "*"
[tool.poetry.dev-dependencies]
pytest = "^3.4"
To build your project as a wheel, execute poetry build
$ poetry build
Building my-project (0.1.0)
- Building sdist
- Built my-project-0.1.0.tar.gz
- Building wheel
- Built my-project-0.1.0-py3-none-any.whl
a dist/ folder is created with a wheel for your project.
Vincent Claes
  • 3,960
  • 44
  • 62
    this will still not add all the specified dependencies in the created wheel file. the individual dependencies will be downloaded when its installed. – rh979 May 06 '21 at 05:09
    @rh979 a wheel is not meant to have all dependencies. Subsequently you could do `pip install path/to/wheel.whl --target /path/to/some/folder` and zip the contents of the 'folder' to have all your dependencies in the zip archive and ship that to the environment where you want to run your code. – Vincent Claes May 06 '21 at 07:27
  • @VincentClaes What would you with that folder once it's on the target machine in order to invoke the program using the bundled dependencies? – mowwwalker Jun 25 '23 at 01:04
    Oh, I think I got it `PYTHONPATH=some/dir python3 some/dir/myapp/__init__.py` – mowwwalker Jun 25 '23 at 01:11
