I'm not sure if this is just a misunderstanding on Capistrano and Rake on my part, but I'm going through the Capistrano 3 set up pages (www.capistranorb.com) and a few of the steps mention how to write up the servers and how to run the basic task of :check_write_permissions.
My problem is when I try to run the example code on my servers using the following server setup, I get unexpected results.
I have my config/deploy/production.rb file set up as such:
server '10.1.28.90', roles: [:web, :app]
server '10.1.246.239', roles: [:db]
I then created the :check_write_permissions task in lib/capistrano/tasks/access_check.rake. I made one small modification to the "on roles(:all)" so it would instead be "on roles(:web)".
desc "Check that we can access everything"
task :check_write_permissions do
  on roles(:web) do |host|
    if test("[ -w #{fetch(:deploy_to)} ]")
      info "#{fetch(:deploy_to)} is writable on #{host}"
    else
      error "#{fetch(:deploy_to)} is not writable on #{host}"
    end
  end
end
When I run the task:
cap production check_write_permissions
OR
bundle exec cap production check_write_permissions
... I am expecting that it will only run the :check_write_permissions code against the servers with a :web role. Instead, my output show that the :db server is also run against with the :check_write_permissions task. This throws exceptions because I do not have a deploy directory on the database server.
DEBUG[90f77252] Running /usr/local/rvm/bin/rvm version on 10.1.246.239
DEBUG[90f77252] Command: /usr/local/rvm/bin/rvm version
DEBUG[fa4e93ec] Running /usr/local/rvm/bin/rvm version on 10.1.28.90
DEBUG[fa4e93ec] Command: /usr/local/rvm/bin/rvm version
DEBUG[90f77252]     bash: /usr/local/rvm/bin/rvm: No such file or directory
DEBUG[fa4e93ec]     rvm 1.25.28 (stable) by Wayne E. Seguin <[email protected]>, Michal Papis <[email protected]> [https://rvm.io/]
DEBUG[fa4e93ec] Finished in 1.060 seconds with exit status 0 (successful).
DEBUG[3583646b] Running /usr/local/rvm/bin/rvm current on 10.1.28.90
DEBUG[3583646b] Command: /usr/local/rvm/bin/rvm current
DEBUG[3583646b]     ruby-2.0.0-p481
DEBUG[3583646b] Finished in 0.286 seconds with exit status 0 (successful).
ruby-2.0.0-p481
DEBUG[b91aa735] Running /usr/local/rvm/bin/rvm 2.0.0-p481 do ruby --version on 10.1.28.90
DEBUG[b91aa735] Command: /usr/local/rvm/bin/rvm 2.0.0-p481 do ruby --version
DEBUG[b91aa735]     ruby 2.0.0p481 (2014-05-08 revision 45883) [x86_64-linux]
DEBUG[b91aa735] Finished in 0.400 seconds with exit status 0 (successful).
cap aborted!
SSHKit::Runner::ExecuteError: Exception while executing on host 10.1.246.239: rvm exit status: 127
rvm stdout: Nothing written
rvm stderr: bash: /usr/local/rvm/bin/rvm: No such file or directory
When I run the task with a ROLE filter in the command I execute, such as:
ROLES=web cap production check_write_permissions
This works as expected. I see only the web server get the task run against it.
DEBUG[7974b8ee] Running /usr/local/rvm/bin/rvm version on 10.1.28.90
DEBUG[7974b8ee] Command: /usr/local/rvm/bin/rvm version
DEBUG[7974b8ee]     rvm 1.25.28 (stable) by Wayne E. Seguin <[email protected]>, Michal Papis <[email protected]> [https://rvm.io/]
DEBUG[7974b8ee] Finished in 1.062 seconds with exit status 0 (successful).
DEBUG[23f666d8] Running /usr/local/rvm/bin/rvm current on 10.1.28.90
DEBUG[23f666d8] Command: /usr/local/rvm/bin/rvm current
DEBUG[23f666d8]     ruby-2.0.0-p481
DEBUG[23f666d8] Finished in 0.297 seconds with exit status 0 (successful).
ruby-2.0.0-p481
DEBUG[7ae64240] Running /usr/local/rvm/bin/rvm 2.0.0-p481 do ruby --version on 10.1.28.90
DEBUG[7ae64240] Command: /usr/local/rvm/bin/rvm 2.0.0-p481 do ruby --version
DEBUG[7ae64240]     ruby 2.0.0p481 (2014-05-08 revision 45883) [x86_64-linux]
DEBUG[7ae64240] Finished in 0.387 seconds with exit status 0 (successful).
DEBUG[c0ebccc0] Running /usr/bin/env [ -w /data/union_benefits/ ] on 10.1.28.90
DEBUG[c0ebccc0] Command: [ -w /data/union_benefits/ ]
DEBUG[c0ebccc0] Finished in 0.126 seconds with exit status 1 (failed).
ERROR/data/union_benefits/ is not writable on 10.1.28.90
What is the reason behind this? I have dug through the Capistrano 3.2.1 code a bit and I cannot figure this out. Maybe this is just a misunderstanding on my part of how the roles(...) work, but I can't figure it out.
Jon
  • 793
  • Old question, did you found an answer by yourself? – LaurentG Aug 29 '16 at 16:26
  • I never figured it out at the time. I just let it deploy the code to both web and db server and went on to other things. According to the Capistrano documentation now (http://capistranorb.com/documentation/advanced-features/property-filtering/), it should work but I can't tried changing it again. – Jon Aug 30 '16 at 19:46
