I have the ssh keys added in Bitbucket. If I do ssh -T [email protected] he says I'm logged in. But when I do a git push/pull I get the following message
conq: repository does not exist.
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
My cat .git/config outputs:
[core]
    repositoryformatversion = 0
    filemode = true
    bare = false
    logallrefupdates = true
    ignorecase = true
    precomposeunicode = true
[remote "origin"]
    url = [email protected]:myUserName/myGitRepo.git
    fetch = +refs/heads/*:refs/remotes/origin/*
[branch "master"]
    remote = origin
    merge = refs/heads/master
[remote "heroku"]
    url = [email protected]:herokuUrl.git
    fetch = +refs/heads/*:refs/remotes/heroku/*
[branch "somebranch"]
    remote = origin
    merge = refs/heads/somebranch
if I do:
git remote -v
prints out:
heroku  [email protected]:herokuUrl.git (fetch)
heroku  [email protected]:herokuUrl.git (push)
origin  [email protected]:myUserName/myRepo.git (fetch)
origin  [email protected]:myUserName/myRepo.git (push)
tvieira
  • 1,865
  • 28
  • 45
    config looks fine, does repository realy exist, and how did you managed to copy key https://confluence.atlassian.com/display/BITBUCKET/Set+up+SSH+for+Git ? – klerk Jul 21 '14 at 22:25
    yup, I edit with the result of the `git remote -v` – tvieira Jul 21 '14 at 22:28
I got the same message, and I had to remove my user id from the path.... So instead of:
What worked was:
url = [email protected]:myGitRepo.git
o11c
  • 15,265
  • 50
  • 75
brain
  • 126
This error is because you renamed on bitbucket. First you check:
git remote -v origin [email protected]:OldName/wp_tanhoangminhgroup.com.vn.git
then you must change the path under new name
git remote set-url [email protected]:NewName/wp_tanhoangminhgroup.com.vn.git
Sanji
  • 109
Make sure you're not adding the SSH key under "Deployment Key" in your Bitbucket repository's settings. What you in fact need to do is add the SSH key under "Manage Account" (Click your Avatar)> "SSH Keys". There's an explanation in this post
Community
osehgol
  • 111
