I need to put element to the right side of page.
This element:
element
To the right side of page. Like this:
I found only pull-right helper class, but I have been realizing, it wouldn't help me, because it based on float. So I started research and first result in google is this result. It says, that I should use pull-right. Well, I tried...
I tried this:
<a href="#" class="btn btn-default btn-lg pull-right" role="button"><span class="glyphicon glyphicon-plus"></span> Создать заказ</span></a>
I got this obvious result:
You can see that third heading in upper row is displaced.
So what exactly I need to do right align any element using bootstrap api?
I understand, that I can search how to center/left/right div and I will find some working results, but it will be not bootstrap solution.
Community
Sharikov Vladislav
  • 7,049
  • 50
  • 87
I think your answer is ".pull-right" class. You may look at it Bootstrap 3 Documentation Helper Classes. I think you can use 2 methods for this.
1) For amateurs :
<div class="col-sm-8"></div> /*Empty div for left alignment*/
<div class="col-sm-4"><div class="btn btn-default">Your Text on Button</div></div> /*This is your button*/
After this code you can use your headings. I mean your button and your heading have to apart from each other.
But as I said this is really terrible for you. And I think it will occur some problem for responsive design.
2)This is for pro Bootstrappers
<div class="col-xs-12"><div class="btn btn-default pull-right>Your Button Text</div></div>
Again after this code you can use your headings. I mean your button and your heading have to apart from each other. You should have to get attention on ".pull-right" class. You just use it on the right place.
I think this will be work for you!
Maybe you want to look at it : How can I get my Twitter Bootstrap buttons to right align?
Community
Emre Doğan
  • 137
