Objective: To send mail (using sendmail) with HTML body and binary attachment.
Followed the guidelines specified in the following links
http://www.unix.com/shell-programming-scripting/159522-sendmail-html-body-attachment-2.html
http://www.unix.com/shell-programming-scripting/58448-sendmail-attachment.html
It is working to the extent that, either HTML body or the binary attachment with uuencode, but not both.
Given below is a snippet of the shell script to sendmail. With this, the HTML body is coming fine, but the attachment is getting encoded/decoded wrongly and unable to view the same.
Please advise.
#!/usr/bin/ksh
export MAILFROM="[email protected]"
export MAILTO="[email protected]"
export SUBJECT="Test PDF for Email"
export BODY="email_body.htm"
export ATTACH="file.pdf"
export MAILPART=`uuidgen` ## Generates Unique ID
 echo "From: $MAILFROM"
 echo "To: $MAILTO"
 echo "Subject: $SUBJECT"
 echo "MIME-Version: 1.0"
 echo "Content-Type: multipart/mixed; boundary=\"-$MAILPART\""
 echo "---$MAILPART"
 echo "Content-Type: text/html"
 echo "Content-Disposition: inline"
 cat $BODY
 echo "---$MAILPART"
 echo 'Content-Type: application/pdf; name="'$(basename $ATTACH)'"'
 echo "Content-Transfer-Encoding: base64"
 echo 'Content-Disposition: attachment; filename="'$(basename $ATTACH)'"'
 uuencode -m $ATTACH $(basename $ATTACH)
 echo "---$MAILPART--"
) | /usr/sbin/sendmail $MAILTO
I am using HP-UX ia64. Have searched through the forum and web and found references mostly to PHP, Python, etc.
compuneo
  • 351
  • Using `mutt -a` is much easier: http://www.mutt.org/doc/man_page.html – ceving Jun 21 '12 at 09:09
  • Thanks, but the current server setup restricts me to sendmail only :-(. Also, mutt is not installed/setup on the server – compuneo Jun 21 '12 at 10:12
  • Send HTML body email with a plain text attachment with sendmail: http://stackoverflow.com/questions/17359/how-do-i-send-a-file-as-an-email-attachment-using-linux-command-line/14213935#14213935 – Eric Leschinski Jan 16 '13 at 04:19
Changing the Content transfer encoding type within the email from base64 to uuencode resolved the issue. Thanks for the inputs so far.
Given below is the revised script that works.
#!/usr/bin/ksh
export MAILPART_BODY=`uuidgen` ## Generates Unique ID
 echo "To: $MAILTO"
 echo "Content-Type: multipart/mixed; boundary=\"$MAILPART\""
 echo ""
 echo "--$MAILPART"
 echo "Content-Type: multipart/alternative; boundary=\"$MAILPART_BODY\""
 echo ""
 echo "--$MAILPART_BODY"
 echo "Content-Type: text/plain; charset=ISO-8859-1"
 echo "You need to enable HTML option for email"
 echo "Content-Type: text/html; charset=ISO-8859-1"
 cat $BODY
 echo "--$MAILPART_BODY--"
 echo "--$MAILPART"
 echo "Content-Transfer-Encoding: uuencode"
 echo ""
 #uuencode -m $ATTACH $(basename $ATTACH)
 uuencode $ATTACH $(basename $ATTACH)
 echo "--$MAILPART--"
) > email_`date '+%Y%m%d_%H%M%S'`.out
compuneo
  • 351
try adding a new line after uuencode
and try also without -m
Bhavesh G
  • 3,000
  • 39
  • 66
Nahuel Fouilleul
  • 18,726
  • 36
  • uuencode -m is adding a new line at the end automatically. I had already tried with -m and it did not work either. I have tried again both suggestions from you and the same problem (attachment comes, but invalid). – compuneo Jun 21 '12 at 12:33
