This is the most popular way (it seems to me) of checking if a value is in an array:
for (int x : array)
if (x == value)
return true;
return false;
However, in a book I’ve read many years ago by, probably, Wirth or Dijkstra, it was said that this style is better (when compared to a while-loop with an exit inside):
int i = 0;
while (i < array.length && array[i] != value)
i++;
return i < array.length;
This way the additional exit condition becomes an explicit part of the loop invariant, there are no hidden conditions and exits inside the loop, everything is more obvious and more in a structured-programming way. I generally preferred this latter pattern whenever possible and used the for
-loop to only iterate from a
to b
And yet I cannot say that the first version is less clear. Maybe it is even clearer and easier to understand, at least for very beginners. So I’m still asking myself the question of which one is better?
Maybe someone can give a good rationale in favor of one of the methods?
Update: This is not a question of multiple function return points, lambdas or finding an element in an array per se. It’s about how to write loops with more complex invariants than a single inequality.
Update: OK, I see the point of people who answer and comment: I mixed-in the foreach loop here, which itself is already much more clear and readable than a while-loop. I should not have done that. But this is also an interesting question, so let's leave it as it is: foreach-loop and an extra condition inside, or a while-loop with an explicit loop invariant and a post-condition after. It seems that the foreach-loop with a condition and an exit/break is winning. I will create an additional question without the foreach-loop (for a linked list).
collection.contains(foo)
– Berin Loritsch Aug 10 '18 at 20:17
