I was recently writing a small piece of code which would indicate in a human-friendly way how old an event is. For instance, it could indicate that the event happened “Three weeks ago” or “A month ago” or “Yesterday.”
The requirements were relatively clear and this was a perfect case for test driven development. I wrote the tests one by one, implementing the code to pass each test, and everything seemed to work perfectly. Until a bug appeared in production.
Here's the relevant piece of code:
now = datetime.datetime.utcnow()
today = now.date()
if event_date.date() == today:
return "Today"
yesterday = today - datetime.timedelta(1)
if event_date.date() == yesterday:
return "Yesterday"
delta = (now - event_date).days
if delta < 7:
return _number_to_text(delta) + " days ago"
if delta < 30:
weeks = math.floor(delta / 7)
if weeks == 1:
return "A week ago"
return _number_to_text(weeks) + " weeks ago"
if delta < 365:
... # Handle months and years in similar manner.
The tests were checking the case of an event happening today, yesterday, a four days ago, two weeks ago, a week ago, etc., and the code was built accordingly.
What I missed is that an event can happen a day before yesterday, while being one day ago: for instance an event happening twenty six hours ago would be one day ago, while not exactly yesterday if now is 1 a.m. More exactly, it's one point something, but since the delta
is an integer, it will be just one. In this case, the application displays “One days ago,” which is obviously unexpected and unhandled in the code. It can be fixed by adding:
if delta == 1:
return "A day ago"
just after computing the delta
While the only negative consequence of the bug is that I wasted half an hour wondering how this case could happen (and believing that it has to do with time zones, despite the uniform use of UTC in the code), its presence is troubling me. It indicates that:
- It's very easy to commit a logical mistake even in a such simple source code.
- Test driven development didn't help.
Also worrisome is that I can't see how could such bugs be avoided. Aside thinking more before writing code, the only way I can think of is to add lots of asserts for the cases that I believe would never happen (like I believed that a day ago is necessarily yesterday), and then to loop through every second for the past ten years, checking for any assertion violation, which seems too complex.
How could I avoid creating this bug in the first place?
, and you then dismiss the solution as being too complex. You're a computer programmer. You're in the business of managing complexity. There are only 315 million seconds in ten years! I have a cheap machine on my desk right now that does four billion operations per second, so get on it. Write a program that tests every second for the last ten years and asserts if there's a problem, and then you'll know if there's a problem! – Eric Lippert Jul 13 '18 at 23:09
