I received great feedback from the other answers at the time I posted this question. I was reminded of this scenario again today and I thought of a couple specific new ways that this can be handled, and I'm realizing now it appears to be very much in line with the answers I received before. To explain this I need to make a distinction between the implementor and the instantiator.
Instantiator (external code) vs Implementor (internal code)
I'll refer to the implementor of the Toggler class as implementor and the code that uses it and at some point instantiates it as instantiator.
The Toggler
class implementation should not be overly-concerned about all the combinations of ways it can be used by the code that'll instantiate it. It should just do what makes sense in regards to it's own class implementation. It's up to the instantiator to decide how it'll be used. The implementor should probably be aware what it's own interface looks like and that it should be clean/simple, and as such it knows how it can be used but it isn't responsible for all the ways it will be used.
Option 1: If I separate interfaces
Let's say it is implemented as such:
public class Toggler : IAutoToggler, IManualToggler { ... }
Now at this point we can already easily do IAutoToggler autoToggler = new Toggler();
to only program to the Auto toggling interface and same for manual toggling. But the concern now is what if I want both? This responsibility falls to the instantiator. As mentioned in John Wu's answer this can be handled by an IoC container and with dependency injection one way could be to inject both interfaces into one classes constructor and use the interfaces separately in a single class that wraps it.
public class TogglerHandler
private readonly IAutoToggler _autoToggler;
private readonly IManualToggler _ toggler;
public TogglerHandler(IAutoToggler autoToggler, IManualToggler toggler) {...}
// exposing access to both underlying interfaces here:
public IEnumerable<IToggleable> Toggle(IAttribute attribute) {...}
public void Toggle(IEnumerable<IToggleable> toggles) {...}
Another way to go about this is to subclass the Toggler class and provide your own interface:
public interface IMixedToggler : IAutoToggler, IManualToggler {}
public class MixedToggler : Toggler, IMixedToggler
// somewhere using the code now can use a mixed toggling interface
IMixedToggler toggler = new MixedToggler();
Option 2: If I make it a single interface
Fabio mentioned that it makes sense here to use a single interface.
Let's say the implementation is like this instead and has the action methods previously in a single interface:
public interface IToggler
IEnumerable<IToggleable> ToggleByAttribute(IAttribute attribute);
void Toggle(IEnumerable<IToggleable> toggles);
public class Toggler : IToggler { ... }
Now the instantiator or user of this interface might not need the full interface. This responsibility to expose only what is needed falls on the instantiator that will use the IToggler implementation. One possible way is to wrap it again, so let's say only the auto-toggling is needed:
public interface IAutoToggler
public class AutoToggler : Toggler, IAutoToggler
// somewhere using the code now can only use auto-toggler interface
IAutoToggler autoToggler = new AutoToggler();
Conclusion
What I've concluded is that no matter whether I separated the interface or kept it a single one, it is still possible to expose or restrict access to it via inheritance or by wrapping the code. The reason I had a hard time seeing this before is because I was both the one who implements that class and also the one who instantiates it but perhaps making this role distinction is useful in making these kinds of decisions.
When designing the interface of an implementation do it such that it makes the most sense for the internal implementation point of view, and for external code calling it either use it as is if it gives you access to what you need or change it to a form that makes more sense to interact with.
In answer to my original question, the IMixedToggler interface should not have been created/implemented. It's only purpose would be to have an additional way of interfacing with the class. That should have been figured out by the code the instantiates/uses it as the responsible fell over there in external code.
Side Note
This code excerpt is from from Kestrel's Http Parser:
public class HttpParser<TRequestHandler>
: IHttpParser<TRequestHandler>
where TRequestHandler
: IHttpHeadersHandler,
IHttpRequestLineHandler
This example actually led me to conclude that internal implementation should not dictate how it's going to be used. The HttpParseObject cannot be initialized without there being an interface existing that are both IHttpHeadersHandler and IHttpRequestLineHandler. So to even initialize this thing you need to have an interface that isn't even specified directly here, it only says it needs an interface that inherits from both of those. So essentially it is enforcing that the instantiator create a new interface that conforms to what it wants:
interface IFoo: IHttpHeadersHandler, IHttpRequestLineHandler { }
var parser = new HttpParser<IFoo>(true);
AutoToggle
andManualToggle
not related to each other, then this class will violate Single Responsibility Principal. What prevents you from using two instances instead of one. With one instance linemixerToggler.Toggle
can be confusing because will be difficult to recognise which implementation is called – Fabio Apr 10 '17 at 20:27void Toggle(toggleables)
takes in specific things to toggle while theIEnumerable<Toggleables> Toggle(attribute)
takes in an attribute and returns what got toggled based on the toggleables containing such attribute. It might be confusing since I tried to generalize the code from a concrete example. I'm using this design for a "Guess Who" game where characters can be toggled manually/individually or automatically based on what characteristics they have. – morbidhawk Apr 11 '17 at 12:21
