A large SQL transactional database has more than 100 tables (and it will grow). One of them is called Order. Then, there is another table WorkLoad which derives from Order and many other joined table which contains a list of all active order. Every time an order record is created, if it meets certain conditions, it should be instantly inserted into WorkLoad table. And finally, there is a third table WorkLoadAggregation which displays aggregated data grouped by date and shop and it is completely built from WorkLoad table. WorkLoadAggregation should also display live data meaning that if a record is inserted in WorkLoad table then matching date/shop aggregation should also be updated.
My idea was to handle this by triggers:
- When record is inserted in Order table, trigger calls stored procedure which inserts record into WorkLoad table
- When Order record is deleted trigger deletes the record from WorkLoad table
- When Order record is updated in a way that it doesn't meet WorkLoad conditions, trigger deletes the record from WorkLoad table
- When record is inserted/deleted/updated in WorkLoad table, trigger calls stored procedure which updates matching date/shop aggregated record in WorkLoadAggregation table
I haven't used triggers that much in such large transaction dbs and for such frequent calls. Is there anything bad in this approach? My biggest concern is usage of "chained triggers", meaning that trigger on one table activates trigger on another table. I've been reading few articles which state that developers should be very cautious when using triggers. Are there any better solutions? Should I consider any NoSQL solution?
WorkLoad
have to by a physical table? Justin's suggestion is a sound one. Create a view. Making it an indexed view is optional. – gvee Mar 17 '15 at 15:37WorkLoad
should be table because it's kind of staging table which is used to populateWorkLoadAggregation
. I did made some changes to my initial idea -WorkLoadAggregation
is actually an indexed view which queriesWorkLoad
table. One reason whyWorkLoad
can't be an indexed view is becauseWorkLoadAggregation
indexed view can't be built on top of another view – ilija veselica Mar 17 '15 at 16:02When record is inserted in Order table, trigger calls stored procedure which inserts record into WorkLoad table
I'm looking for the article that explains why you shouldn't use stored procedures, that's why I didn't reply. Short story, you need to respect the rollbacks, by send data to a procedure, you lose that, hence data integrity hazard. – Apr 13 '15 at 11:27
