For methods that never access instance variable or static variable and they act just like a function (name-spaced) and they are deterministic base on only the input arguments , I want to ask, are there any consideration if I change all of them to static method?
I keep hearing people saying it static method is poor, but I am looking for some real code example on my above case.
user34401
  • 751
    Static methods are poor when they also access mutable static variables. They're fine for the kind of task you mentioned. – Doval Aug 15 '14 at 17:36
  • Asked before in http://programmers.stackexchange.com/questions/242940/significant-amount-of-the-time-i-cant-think-of-a-reason-to-have-an-object-inst/242943#242943 – sea-rob Aug 16 '14 at 00:23
The problem with static methods is mockability and more generally substitutability. Although there are mocking frameworks which will allow you to mock static methods, there is broader support for mocking a non-static method, and it's simple to do yourself by subclassing.
Say I'm testing class A which interacts with class B. If it calls only non-static members of B, then I can inject a replacement for B which behaves the way I need, for instance for testing. But if it calls a static member of B, it's hard (depending on your mocking framework, sometimes impossible) to mock. So I have to use a real B - or the real B class - in my test of A; now I have a more complicated test, and one which is testing more than the unit (A) I'm interested in. It's more fragile and harder to reason about than if I can just mock out the method.
I think that's the best rationale for avoiding static methods.
Carl Manaster
  • 4,183
    Good answer, but that's only an issue when static methods interact with the outside world or aren't deterministic. Calling, say, Math.pow is never an issue because there's no pre-test or post-test environment to set up or tear down. – Doval Aug 15 '14 at 17:47
    True, but on the other hand a static random number method - which you would at first thing also would be fine as a static - is a pain when you want deterministic testing. Static methods certainly have their place, but the OP was looking for reasons one might not want them. – Carl Manaster Aug 15 '14 at 17:49
    Static methods, if used properly, don't need to be mocked. Not sure what you mean by substitutability; written properly, a static method is perfectly substitutable. I think the grousing about static methods arises out of their misuse and abuse. – Robert Harvey Aug 15 '14 at 17:51
    @CarlManaster We're not in disagreement there (notice I mentioned determinism) but I'd argue that a static RNG method with no arguments is bad design. That's global mutable state. – Doval Aug 15 '14 at 17:54
I feel like static method's encourage behavior like this. In this case we have a global class with a static function. We are hiding the fact that Foo depends on StaticWorker.DoWork().
Static Method
public class Foo
    public void Bar()
        StaticWorker.DoWork();
On the other hand, instance-level methods encourage passing the dependent object. Which is better than reaching into a global.
Instance Method
public class Foo
    Worker Worker;
    public Foo(Worker worker)
        this.Worker = worker;
    public void Bar()
        this.Worker.DoWork();
Now of course you could pass in a function, but I still like the abstraction I get with objects.
Another huge benefit of instance-level methods is that the class can implement an interface which you cannot do for a static method.
This is similar to the singleton argument. Singleton's themselves don't cause damage if used properly, but it makes it easier for people to call the singleton all over their code without passing it, once again creating invisible dependencies and global state.
There are exceptions to the rule. Sometimes you have a small, lightweight method. It will never change, and is not a dependency for anything else, I might make it static. You have to use your best judgement on a case by case basis, but I would say favor instances, especially if you have any doubts.
I feel like there are several benefits to using instance methods and all I have to do is instantiate an object. A small price to pay for the rewards.
Despertar
  • 603
Declaring a pure functions as static is correct in my opinion. It would be awkward to require creating an instance of a stateless object just to call a function.
There are cases however where you need them to be in an object instance. For example when you pass that function to another method, as you do with a Comparator in a sort method. More generally, when you need to substitute your function, or a set of functions by another one, you'll need an instance.
The bad reputation of static methods comes from when they are used as a substitute for the Singleton pattern. But in this case, there is some state stored in static variables.
Florian F
  • 1,127
