So I am building an application with Angular and have started to get into UI testing with DalekJS (http://dalekjs.com). As I have been writing these tests I have been thinking to myself, should I even bother with writing unit test that that are UI/UX components.
Now my angular services generally don't have anything to do with the DOM or directly rendering stuff on the page so those I unit test and it make sense however angular directives are components that render things directly to the page and writing unit tests seems like 1. It is not an effective way to test UI/UX components and 2. It would overlap with UI/UX Tests.
For point #1, unit test (at least ones I have seen) don't actually write anything to a browser and render it. For thing that require DOM, you generally mock the DOM in a variable and use that to test whatever you need to test. If you have an error with a test, you can't load it up in a browser and play around with it like you could with UI/UX tests (which in my experience runs against code that is the true application that renders and everything).
For point #2, one of my directives has a property called contentVisible. Now I can write a unit test that make sure that property is the correct value at certain points but that really don't not test what I truly want to test because even if contentVisible is set to false, the content still might be rendering to the screen which UI/UX test would pick up.
Is it still worth the effort to write unit test for UI/UX Components where UI tests would be able to pick up everything the unit test would plus also do a better job since it can test what is actually rendered?
Exception The one exception case where I would need a unit test is for certain ajax requests. For example, making sure an ajax request is not made of that an ajax request that does not make and changes to the UI are things that can only be tested with unit tests.
-- No. That's why UI testing frameworks exist. How would you unit test a UI anyway? – Robert Harvey Aug 05 '13 at 19:09
