People often give me the "divide and conquer" tip, but I think for some problems it's not nearly enough. The problem with such a complex problem as the Hanoi Tower problem is that you can't even simulate or abstract parts of the problems even if you divide it into parts if you know what I mean. So, can anyone give me a step-by-step approach in tackling such a complex and difficult problem?
4How is the Hanoi Tower problem too complex to simulate? If you have an example of a complex problem that you have actually faced it would be easier to help you with regards to how to tackle the problem. – Mike Jun 13 '13 at 02:30
It's hard to simulate when you have n > 5. – John Locke Jun 13 '13 at 03:26
Of course the trick with divide and conquer is deciding exactly where to divide. – Greg Hewgill Jun 13 '13 at 03:29
How is n > 5 more difficult that n = 5 (or 4)? – Jun 13 '13 at 03:58
My first tip would be to load a browser, go to "www.google.com" and typing "solving towers of hanoi" into the handy search box. – Gort the Robot Jun 13 '13 at 04:02
1You may find the SO tag towers-of-hanoi useful. – Jun 13 '13 at 05:39
I wouldn't go as far as saying that the Hanoi Tower problem is extremely complex. I mean, I solved it when I was in high school... – Radu Murzea Jun 13 '13 at 08:19
writing an algorithm for it is hard – John Locke Jun 14 '13 at 22:52
@ Steven Burnap I want to know how I can do it on my own. – John Locke Jun 15 '13 at 00:25
Divide and conquer is about making the problem so small that it is absolutely trivial to solve. Then you make it slightly larger, and slightly larger, and look for patterns.
For Towers of Hanoi, what is the simplest possible problem? One disk, moved straight to its destination. The second simplest is two disks. First you move one disk to a temporary spot, you move the second to the destination, then you move the first disk to the destination.
The next iteration is harder, but the trick here is to recognize that you already have proved you can move a stack of two disks, so you can abstract that away. You move a stack of two to a temporary location, move the nth disk to its destination, then move the stack of two on top of it.
You now start to see a pattern emerge. For n disks, you first move a stack of n-1 disks, then the nth disk, then you move the stack on top of it. You know this is guaranteed to work, because you can define n-1 in terms of n-2, which you can define in terms of n-3, and so on until you eventually get to one disk, which is trivial.
Where people get into trouble is trying to hold every single iteration in their head at once. You have to learn to trust that it works for n-1.
Here's a complete working implementation in C. Pass in n
as an argument.
#include <stdio.h>
#include <stdlib.h>
void hanoi(int n, const char* from, const char* to, const char* temp)
if (n == 1)
printf("Move disk 1 from %s to %s.\n", from, to);
else
// Move n-1 sized stack to temporary location
hanoi(n - 1, from, temp, to);
printf("Move disk %d from %s to %s.\n", n, from, to);
// Move n-1 sized stack from temp location to destination
hanoi(n - 1, temp, to, from);
int main(int argc, char* argv[])
if (argc < 2)
return -1;
int n = atoi(argv[1]);
hanoi(n, "left", "right", "middle");
return 0;
- 147,435
There are many steps involved so writing a code for it is quite hard. I can solve the problem by hand with no problem. – John Locke Jun 14 '13 at 22:56
It's not as simple as you make it out to be. You don't just move the nth disk to its destination, there are intermediary steps you have to consider; otherwise, developing an algorithm for it would be very simple. – John Locke Jun 14 '13 at 23:39
2It is as simple as that, and I've added working code to my answer that shows it. Feel free to test it. The intermediary steps are all handled by trusting that it works for
n-1
. – Karl Bielefeldt Jun 15 '13 at 03:46
