22
In programming we're often faced with a choice: cover each conceivable use case individually, or solve the general problem:
XKCD - The General Problem
Its obvious that solving the immediate problem is faster, however creating a generalized solution will save time in the future.
How do I know when it's best to try and cover a finite list of cases, or make a generic system to cover all possibilities?
AncientSwordRage
  • 1,033
  • 24
6 Answers6
32
First, you pass the salt. Then you pass the pepper. Then you pass the grated parmesan cheese. At this point, you have enough experience to start developing a general condiment-passing system.
It works in software projects in the same way: use special purpose systems that you develop as your learning steps to generalized ones, so when it is time to start your general-purpose system, you have a better confidence in what you are building, because you have several special-purpose systems under your belt.
Sergey Kalinichenko
  • 17,471
  • 58
  • 73
Experience.
The only way to know is to have tried one path before, seen how it's bitten you in the ass (or you've wasted a bunch of time). Repeat until you get bit in the ass less.
Even then, you don't really know; you just have a better guess.
Telastyn
  • 109,398
To build on the answers from dasblinkenlight and Paddy3118, if you don't have multiple cases to implement, then you don't need to generalize! The reason the XKCD cartoon is funny is that it lampoons premature generalization. Upon being asked to pass the salt, the unseen character immediately leaps to "developing a system to pass arbitrary condiments" when all the first character asked for was the salt. This is a good joke for developers, since I think we've all seen cases of premature generalization.
The principle opposed to premature generalization is YAGNI (You Ain't Gonna Need It). There are many materials about this available on the web, but basically YAGNI points out a number of risks in generalizing without the benefit of several actual use cases at hand, including the possibility that multiple use cases might not actually appear. Or, more subtly, the lack of actual use cases requires one to make assumptions about what's necessary in the future. These assumptions can be, and often are, incorrect.
Stuart Marks
  • 2,235
It seems easier to be generic in the small, i.e. don't make a class to handle a lookup table that maps integers to strings when you can make a reasonable dictionary class that handles any pair of types (where the first type supports some type of comparison).
In a previous life I did a lot of industrial automation projects for machinery that handled a continuous web of material. Steel, aluminum, paper, plastic, ... . You unroll it at one end and roll it up again at the other after doing something useful in the middle. In one industry you start at the "payoff reel", not the "unwinder". If you use the wrong terminology then you're an idiot in the client's multi-million dollar eyes. You would be amazed at how little could be abstracted for reuse from one project to the next. OTOH, one could often create a framework or template as a starting point. It would be customized for the job at hand, but at least it had the benefit of learning from prior projects. And everyone on the team knew where we were starting from.
HABO
  • 121
Do it once, do it twice, do it three times, generalize.
One, two, many!
On the second case you should be thinking on generalization. On being asked for the third you should supply it from the generalized code and use the first and second case previously solved individually as test cases.
Paddy3118
  • 617
