I'm trying to create a kind of turn-by-turn satellite navigation system using the iOS SDK. I get the directions from the server and draw them on the map, then I keep getting location updates from the iPhone's GPS chip. Currently I start by finding the nearest turning point then, each time the user comes within a certain distance of the next turning point, a verbal cue is given and the turning point index is incremented. This is a delicate system and I'd like to make it more robust so I can tell when the user is going the wrong direction etc.
Basically I'm looking for some literature about turn-by-turn navigation, in terms of tracking the user's progress and whether they're going the right direction. I'd have thought there's a lot of research out there but I can't seem to find anything apart from simple tutorials on how to use a given SDK or directions API. Can anyone direct me to a good run-through of the various techniques used in software such as TomTom or Google Maps Navigation?
